hi
i make a simple project about turn on or off the led and the options to make it blink or turn up and down the light and it worked but the problem is that when i enter the data in serial monitor
for turn it on or off it wait for 1 sec and perform the command .
just want to know why its slow and i know my arduino is ok i tested with other project.
here is the sketch
int led =3;
int potensio ;
int ohmi;
int shedat;
int _speed;
int onoff=0;
char choice=0;
pinMode(led,OUTPUT);
potensio = analogRead(A0); // reading potentiometer and pass a number between 0_1023
while (Serial.available())
onoff = Serial.parseInt(); // argument that determination led is off or on
choice = Serial.parseInt(); // argument that determination led is on or blinking or we can
if(onoff == 1 && choice == 0) // choice = 0 means we just want to turn on led
digitalWrite(led,HIGH); // turn on led
else if(onoff == 0 ) // it does not matter what choice is
digitalWrite(led,LOW); // turn off led
ohmi = map(potensio,0,1023,0,10000); // using 10k ohm potetiometer
Serial.print(ohmi); // printing true potensiometer value
if(onoff ==1 && choice == 1) // choice 1 means we want to change the blinking time
_speed = map(potensio,0,1023,0,1000); //delay with speed mapping to 0 to 1000 mili sec
digitalWrite(led,HIGH); //turn on led
delay(_speed); //delaying
digitalWrite(led,LOW); //turn off led
delay(_speed); // delaying
else if(onoff ==1 && choice == 2) // choice 2 means we want to turn up or down the led
shedat= map(potensio,0,1023,0,256);
analogWrite(led,shedat); // using pwm for light of led
