so i've had my arduino for about 3 months, and I don't know what i would do with out this forum.
this is my little vu meter.... kind of. it takes serial data from winamp and a big thanks goes to macegr for the winamp plug in code and helping me out.
the volume is a little low on the vids.
this one is using old code, which has been redone.
Arduino code.
const int ledPin = 3;
const int ledPin2 = 4;
const int ledPin3 = 5;
const int ledPin4 = 6;
const int ledPin5 = 7;
const int ledPin6 = 8;
const int ledPin7 = 9;
const int ledPin8 = 10;
const int ledPin9 = 11;
Serial.begin(57600);
pinMode(ledPin, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
pinMode(ledPin4, OUTPUT);
pinMode(ledPin5, OUTPUT);
pinMode(ledPin6, OUTPUT);
pinMode(ledPin7, OUTPUT);
pinMode(ledPin8, OUTPUT);
pinMode(ledPin9, OUTPUT);
int lvl;
int start = 100; // start value from 255 for start range (fine tune lvls)
int total = 0; // for calculations below. <<don't edit>>
int data[9]; // raw serial data <<don't edit>>
int value[10]; // values for the led pins based on the minus value <<dont' edit>>
int check = 0;
// int last[9];
// int off = 0;
// serial data start ---------------
if (Serial.available() >10) {
byte i = Serial.read();
if (int(i) == 255) {
for (int c = 0; c < 9; c++){
data[c] = int(Serial.read());
check = 1;
// if (last[0] == data[0] && last[1] == data[1] && last[2] == data[2] && last[3] == data[3] && last[4] == data[4]){
// off = 1;
// serial data end -----------------
// some math -------------
total = (255 - start) / 9;
value[0] = 0;
value[1] = start;
for (int k = 2; k <= 8; k++){
value[k] = value[k - 1] + total;
//lvl = (data[0] + data[1] + data[2] + data[3] + data[4] + data[5] + data[6] + data[7] + data[8]) / 9;
lvl = (data[0] + data[2] + data[4] + data[6] + data[8]) / 5;
// math end -----------------
//---- single led ------
/*if (check == 1){
if (lvl >= start){
int val = map(lvl, start, 255, 5, 255);
analogWrite(ledPin, val);
if (lvl < start){
analogWrite(ledPin, 5);
// single led end -------------
//----------- solution 1 ----------------
if (lvl == 0){
analogWrite(ledPin, 0);
analogWrite(ledPin2, 0);
analogWrite(ledPin3, 0);
analogWrite(ledPin4, 0);
analogWrite(ledPin5, 0);
analogWrite(ledPin6, 0);
analogWrite(ledPin7, 0);
analogWrite(ledPin8, 0);
analogWrite(ledPin9, 0);
if (lvl > value[0] && lvl <= value[1]) {
analogWrite(ledPin, 220);
if (lvl > value[1] && lvl < value[2]) {
analogWrite(ledPin2, 220);
if (lvl>= value[2] && lvl< value[3]) {
analogWrite(ledPin2,220);
analogWrite(ledPin3, 220);
if ( lvl>= value[3] && lvl<=value[4]) {
analogWrite(ledPin4, 220);
if ( lvl>= value[4] && lvl<=value[5]) {
analogWrite(ledPin5, 220);
if ( lvl>= value[5] && lvl<=value[6]) {
analogWrite(ledPin6, 220);
if ( lvl>= value[6] && lvl<=value[7]) {
analogWrite(ledPin7, 220);
if ( lvl>= value[7] && lvl<=value[8]) {
analogWrite(ledPin8, 220);
if ( lvl>= value[8] && lvl<=value[9]) {
analogWrite(ledPin9, 220);
cheers,
Dave Johnson
