Led will not loop
Hi, sorry to ask but I have been working on this sketch for a few days, and I have I just can’t seem to get the LED to loop I have the rest of it working. what I am trying to do is sequential turn signal using 595 shift register I want the LED to light up one at a time once the last LED is lite up they all turn off instantly and the sequence starts again. Im using a push button at the moment, my issue is I press the button and the LEDs light up in sequence and stay on . i know the problem is something I did or didn’t do, so Im hoping that fresh eye will see it
I have attached the sketch
thanks
sample2.ino (1.25 KB)
therat69:
Hi, sorry to ask but I have been working on this sketch for a few days, and I have I just can't seem to get the LED to loop I have the rest of it working. what I am trying to do is sequential turn signal using 595 shift register I want the LED to light up one at a time once the last LED is lite up they all turn off instantly and the sequence starts again. Im using a push button at the moment, my issue is I press the button and the LEDs light up in sequence and stay on . i know the problem is something I did or didn't do, so Im hoping that fresh eye will see it
thanks
is this not the same as YOUR OTHER POST????
what does it mean to loop a LED ?
post code directly inline with code tags </> so that we can read it… Most participants won’t download a file to their computer.
Hi, this is similar, and the last one is in use at the moment
int latchPin = 9;
int clockPin = 10;
int dataPin = 8;
int buttonPin = 11;
int buttonValue;
int numOfRegisters = 3;
byte* registerState;
  //Initialize array
  registerState = new byte[numOfRegisters];
  for (size_t i = 0; i < numOfRegisters; i++) {
    registerState[i] = 0;
  //set pins to output so you can control the shift register
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(buttonPin, INPUT);
  buttonValue = digitalRead(buttonPin);
  if (buttonValue == HIGH){
    for (int i = 24; i > 0; i--){
    for (int k = 0; k < i; k++){
      regWrite(k, HIGH);
      delay(100);
      regWrite(k, LOW);
    regWrite(i, HIGH);
void regWrite(int pin, bool state){
  //Determines register
  int reg = pin / 8;
  //Determines pin for actual register
  int actualPin = pin - (8 * reg);
  //Begin session
  digitalWrite(latchPin, LOW);
  for (int i = 0; i < numOfRegisters; i++){
    //Get actual states for register
    byte* states = &registerState[i];
    //Update state
    if (i == reg){
      bitWrite(*states, actualPin, state);
    //Write
    shiftOut(dataPin, clockPin, LSBFIRST,  *states);
  //End session
  digitalWrite(latchPin, HIGH);
LEDs don't "loop". They illuminate (or not).
      regWrite(k, HIGH);
      delay(100);
      regWrite(k, LOW);
    regWrite(i, HIGH);
You are lighting ‘pin’ 24 which is one past your array. Your three bytes contain pins 0 through 23.
Are you still holding down the button? The code does nothing unless the button reads HIGH.
Your ‘array of pointers to bytes’ seems overly complicated. Here is a guess as to what it might look like using a simple ‘array of bytes’:
int latchPin = 9;
int clockPin = 10;
int dataPin = 8;
int buttonPin = 11;
int buttonValue;
const byte NumberOfLEDs = 24;
const byte NumberOfRegisters = 3;
byte registers[NumberOfRegisters];
    for (int i = NumberOfLEDs-1; i >= 0; i--)
        regWrite(k, HIGH);
        delay(100);
        regWrite(k, LOW);
      regWrite(i, HIGH);
  int reg = pin / 8;
  int actualPin = pin % 8;
  // Set the bit
  bitWrite(registers[reg], actualPin, state);
  // Update the outputs
  //Begin session
  for (int i = 0; i < NumberOfRegisters; i++)
    shiftOut(dataPin, clockPin, LSBFIRST,  registers[i]);
  //End session
Hi John, thanks you, the code I wrote was almost as long as war and peace the novel and you did it in just under a paragraph and that is experience thanks, I loaded the code, unfortunately it’d does exactly the same a my code , as for the button I only tap it and the led light up but after led lights they stay on but now I know it has to do with the "regWrite(I, HIGH)’ when I comment this line out the leds will flash only
        regWrite(k, HIGH);
        delay(100);
        regWrite(k, LOW);
      regWrite(i, HIGH);
how did you wire your push button ?
sherzaad:
https://forum.arduino.cc/index.php?topic=677650.0
therat69:
so what are you trying to achieve now that is DIFFERENT from then?
ie what is stopping you from re-using/modifying the solution you got then?
J-M-L:
A penny to a Porsche says the input pin is floating. :slight_smile:
Im sorry for wasting everyones time on my stubbiness, And I like to thank John for fine tuning the code and J-M-L for making me look at the way the push button was wired. The issue was not the code but the way I wired the push button!! I sincerely apologise for wasting everyone's time for my stubbiness!! It was easy to blame the software and not the hardware. once again THANK YOU!!
Karma point for reply # 10 :wink:
Don’t worry we all made that mistake at least once
That’s how you learn
