I was working on a project and I found a code online where the project consisted of a LCD menu system that is controlled by 3 buttons. Depending on what you command it, an LED will turn on/off, blink or fade. I want to add another LED light to it with the same menu options as the first one. Curently, when I upload my code, the functions that are suppose to work for the second LED is also working for the first LED. Can anyone help me. I attached below the original code and the code that I edited.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2); // ARDUINO UNO
//LiquidCrystal lcd(3, 2, 1, 7, 8, 9, 10); // ATTINY84
byte buttons[] = {6,7,8}; //10 for additional pin
const byte nrButtons = 3; // change to 4 if additional button added
int menusize = 10;
String menu[] = {
"Menu", //0
"Menu>LED", //1
"Menu>LED>Off", //2
"Menu>LED>On", //3
"Menu>LED>Fade", //4
"Menu>LED>Blink", //5
"Menu>LCDlight", //6
"Menu>Nothing1", //7
"Menu>Nothing2", //8
"Menu>Nothing3" //9
int t;
byte pressedButton, currentPos,currentPosParent, possiblePos[20], possiblePosCount, possiblePosScroll = 0;
String parent = "";
int brightness;
int LCDtoggle = 0;
int fadeAmount = 5;
unsigned long timer = (millis() / 10);
int ledMode = 0;
void updateMenu () {
possiblePosCount = 0;
while (possiblePosCount == 0) {
for (t = 1; t < menusize;t++) {
if (mid(menu[t],1,inStrRev(menu[t],">")-1).equals(menu[currentPos])) {
possiblePos[possiblePosCount] = t;
possiblePosCount = possiblePosCount + 1;
//find the current parent for the current menu
parent = mid(menu[currentPos],1,inStrRev(menu[currentPos],">")-1);
currentPosParent = 0;
for (t = 0; t < menusize; t++) {
if (parent == menu[t]) {currentPosParent = t;}
// reached the end of the Menu line
if (possiblePosCount == 0) {
//Menu Option Items
switch (currentPos) {
case 2:
case 3:
case 4:
case 5://Choose between 2,3,4,5
for (t = 2; t<6; t++) {
if (mid(menu[t],len(menu[t]),1) == "*") {
menu[t] = mid(menu[t],1,len(menu[t])-1);
menu[currentPos] = menu[currentPos] + "*";
case 6: //Toggle
if (mid(menu[currentPos],len(menu[currentPos]),1) == "*") {
menu[currentPos] = mid(menu[currentPos],1,len(menu[currentPos])-1);
//Set Variables
case 2:
ledMode = 0;
case 3:
ledMode = 1;
case 4:
brightness = 128;
ledMode = 2;
case 5:
brightness = 0;
ledMode = 3;
case 6:
LCDtoggle = abs(LCDtoggle - 1);
digitalWrite(13,LCDtoggle);
// go to the parent
currentPos = currentPosParent;
lcd.clear();
lcd.setCursor(0,0); lcd.print(mid(menu[currentPos],inStrRev(menu[currentPos],">")+1,len(menu[currentPos])-inStrRev(menu[currentPos],">")));
lcd.setCursor(0,1); lcd.print(mid(menu[possiblePos[possiblePosScroll]],inStrRev(menu[possiblePos[possiblePosScroll]],">")+1,len(menu[possiblePos[possiblePosScroll]])-inStrRev(menu[possiblePos[possiblePosScroll]],">")));
// Look for a button press
byte checkButtonPress() {
byte bP = 0;
byte rBp = 0;
for (t = 0; t<nrButtons;t++) {
if (digitalRead(buttons[t]) == 0) {bP = (t + 1);}
rBp = bP;
while (bP != 0) { // wait while the button is still down
bP = 0;
return rBp;
lcd.begin(16,2);
lcd.clear();
for (t=0;t<nrButtons;t++) {
pinMode(buttons[t],INPUT_PULLUP);
pinMode(13,OUTPUT);
pinMode(9,OUTPUT);
lcd.setCursor(0,0); lcd.print("HELLO");
updateMenu();
switch (ledMode) {
case 0:
analogWrite(9, 0);
case 1:
analogWrite(9, 255);
case 3:
if ((millis() / 10) - timer > 30) {
brightness = abs(brightness - 255);
analogWrite(9, brightness);
case 2:
if ((millis() / 10) - timer > 3) {
brightness = brightness + fadeAmount;
if (brightness <= 0 || brightness >= 255) {
fadeAmount = -fadeAmount;
pressedButton = checkButtonPress();
if (pressedButton !=0) {
switch (pressedButton) {
case 1:
possiblePosScroll = (possiblePosScroll + 1) % possiblePosCount; // Scroll
// If I wanted a 4 button controll of the menu
//case 4:
// possiblePosScroll = (possiblePosScroll + possiblePosCount - 1) % possiblePosCount; // Scroll
//break;
case 2:
currentPos = possiblePos[possiblePosScroll]; //Okay
case 3:
currentPos = currentPosParent; //Back
updateMenu();
String mid(String str, int start, int len) {
int t = 0;
String u = "";
for (t = 0; t < len;t++) {
u = u + str.charAt(t+start-1);
return u;
int inStrRev(String str,String chr) {
int t = str.length()-1;
int u = 0;
while (t>-1) {
if (str.charAt(t)==chr.charAt(0)) {
u = t+1;t = -1;
t = t - 1;
return u;
int len(String str) {
return str.length();
