LED wont turn off with potentiometer
As I run this code, the LEDs dont turn off when the potentiometer doesnt satisfy the condition. Also the LED2 doesnt seem to come on at all. What am I doing wrong?
#include <Servo.h>
#define POT_PIN 1      // Arduino pin that the potentiometer connects to the Experimenter
#define LED0 11
#define LED1 9
#define LED2 6
#define LED3 3
Servo myservo;  // Create servo object to control a servo
int potVoltage;      // Variable to store the voltage value from the potentiometer
int scaled_val = 0;  // Variable to hold the scaled voltage value
  myservo.attach(10);  // Attaches the servo on pin 10 to the servo object
  pinMode( LED0, OUTPUT);
  pinMode( LED1, OUTPUT);
  pinMode( LED2, OUTPUT);
  pinMode( LED3, OUTPUT);
  potVoltage = analogRead(POT_PIN);  // Reads the voltage of the potentiometer (returns a value between 0 and 1023)
  scaled_val = map(potVoltage, 0, 1024, 0, 180);   // Scale the value to use with the servo (value between 0 and 180)
  myservo.write(scaled_val);       // Sets the servo position according to the scaled value
  if(scaled_val <= 10)
    digitalWrite(LED0, HIGH);
  else if(scaled_val >= 170)
    digitalWrite(LED3, HIGH);
  else if(scaled_val = 45)
    digitalWrite(LED1, HIGH);
  else if(scaled_val != 45)
    digitalWrite(LED1, LOW);
  else if(scaled_val = 135)
    digitalWrite(LED2, HIGH);
  else if(scaled_val != 135)
    digitalWrite(LED2, LOW);
    return 0;
At least this is wrong:
if(scaled_val = 45)
You need ==
Leaving aside the need to change = to == there is a problem with this portion of code
  else if (scaled_val = 45)
  else if (scaled_val != 45)
scaled_val is either going to equal 45 or not so any following tests of its value will not be executed
Thank you for the help! I was able to work it out. Here is my final code.
#include <Servo.h>
#define LED0 11
#define LED1 9
#define LED2 6
#define LED3 3
  potVoltage = analogRead(POT_PIN);  // Reads the voltage of the potentiometer (returns a value between 0 and 1024)
  if(scaled_val <= 3.6)
  else if(scaled_val >= 176.4)
  else if(scaled_val == 45)
  else if(scaled_val == 135)
    digitalWrite(LED0, LOW);
    digitalWrite(LED3, LOW);
    return 0;
[code]
  else if (scaled_val >= 176.4)
There is not much point (pun intended !) in testing an int against a float.
