LED world map
I'm working on a project which is using artificial intelligence. It's a game that where a zombie plague starts and the player has to stop it. So what I need help with finding a way to have the plague spread outward, also moving the players unit. I also need help on having the players unit destroy the plague. If this is possible please help if not I have a back up plan.
How's the LED world map come into play?
LEDs that light with one per country on a globe or something?
CrossRoads:
Ya that is what I was thinking
Ok, how many countries?
With an arduino and a MAX7219, can light up 64 LEDs. With two, 128 LEDs, etc.
Easy to program & use for that.
Connect up your LEDs like this & control from the MAX7219.
(blocked off a couple in this diagram for another discussion, wire up the last 4 in the similar manner).
You can find things like this in larger lots,
http://www.ebay.com/itm/FISHER-MARANTZ-KENWOOD-PIONEER-SANSUI-ONKYO-JVS-REPLACEMENT-LED-POINTER-LAMP-/281108599255?pt=Vintage_Electronics_R2&hash=item417360d1d7
just connect the LEDs to a breakout of pins from the MAX7219.
So what I was thinking was doing one countries for each in the UN (193)
No problem, 3 chips and 1 output pin from an Uno. Or 4 chips for future expansion.
Thanks for the help but how do I program the artificial intelligence.
Uhm, sounds like you need the backup plan!
Or at least a much better description of how the game is to be played.
That's fine and I was prepared for this and will take almost half the work.
