Hi guys. So Im in a bit of a sticky situation. Im planning on covering my ceilling with the LED strip mentioned in the topic. I will be using the variant of 60 led/m. Which means that at 13.2 m there will be 792 LEDs. And the current that it will be drawing is 47.52A which is a ton. I was thinking of spliting the distance in 2 segments or switching to 30 led/m. What do you recommend ?
KuPi:
Another option to consider - do not use max brightness.
I would use 12v 60leds/m ws2811 leds. Keep in mind that these are only addressable every three leds.
The current draw is roughly 3.5amps per 5 meters at full brightness. I would inject power every 2.5m.
