int latchPin = 10;
int clockPin = 13;
int dataPin = 11;
int clock = 9;
int Reset = 8;
int latchPinPORTB = latchPin - 8;
int clockPinPORTB = clockPin - 8;
int dataPinPORTB = dataPin - 8;
int i = 0;
int incomingByte[44];
long scrolling_word[6];
int array_turn=0;
byte patterns[100][6];
byte dummy_array[70][6] ={A,B,C,D,E,F,G,H,I,J,K,L,M,N,O,P,Q,R,S,T,U,V,W,X,Y,Z,SPACE,NUM0,NUM1,NUM2,NUM3,NUM4,NUM5,NUM6,NUM7,NUM8,NUM9,DEVIDE,TWODOTS,DOT,COMA,LINE,QUASTION,MARK,LA,LB,LC,LD,LE,LF,LG,LH,LI,LJ,LK,LL,LM,LN,LO,LP,LQ,LR,LS,LT,LU,LV,LW,LX,LY,LZ};
void setup(){
pinMode(dataPin,OUTPUT);
pinMode(clockPin,OUTPUT);
pinMode(latchPin,OUTPUT);
pinMode(clock,OUTPUT);
pinMode(Reset,OUTPUT);
digitalWrite(Reset,HIGH);
digitalWrite(Reset,LOW);
setupSPI();
void display_word(int loops,byte word_print[][6],int num_patterns,int delay_langth){
i = 0;
for(int g=0;g<6;g++)
scrolling_word[g] = 0;
for(int x=0;x<num_patterns;x++){
for(int r=0;r<6;r++)
scrolling_word[r] |= word_print[x][r];
for (int z=0;z<6;z++){
for(int p=0;p<6;p++)
scrolling_word[p] = scrolling_word[p] << 1;
for(int t=0;t<delay_langth;t++){
for(int y=0;y<6;y++){
if(i == 6){
i = 0;
latchOff();
spi_transfer(make_word(0x01000000,y));
spi_transfer(make_word(0x00010000,y));
spi_transfer(make_word(0x00000100,y));
latchOn();
delayMicroseconds(800);
latchOff();
spi_transfer(0);
spi_transfer(0);
spi_transfer(0);
latchOn();
digitalWrite(clock,HIGH);
digitalWrite(clock,LOW);
i++;
finish_scroll(delay_langth);
void finish_scroll(int delay_scroll){
for (int n=0;n<24;n++){
for(int h=0;h<6;h++)
scrolling_word = scrolling_word << 1;
for(int w=0;w<delay_scroll;w++){
for(int k=0;k<6;k++){
if(i == 6){
i = 0;
latchOff();
spi_transfer(make_word(0x01000000,k));
spi_transfer(make_word(0x00010000,k));
spi_transfer(make_word(0x00000100,k));
latchOn();
latchOff();
spi_transfer(0);
spi_transfer(0);
spi_transfer(0);
latchOn();
i++;
byte make_word (long posistion,byte turn){
byte dummy_word = 0;
for(int q=0;q<8;q++){
if(scrolling_word[turn] & (posistion<<q))
dummy_word |= 0x01<<q;
return dummy_word;
// send data only when you receive data:
if(Serial.available() > 0){
delay(100);
incomingByte[array_turn] = Serial.read();
array_turn++;
else{
if(array_turn != 0){
for(int az=0;az<array_turn;az++){
if((incomingByte[az] > 64 && incomingByte[az] < 91) || (incomingByte[az] > 96 && incomingByte[az] < 123)){
if(incomingByte[az] > 64 && incomingByte[az] < 91){
for(int lal=0;lal<6;lal++)
patterns[az][lal] = dummy_array[incomingByte[az] - 65][lal];
else{
patterns[az][lal] = dummy_array[incomingByte[az] - 53][lal];
else{
switch(incomingByte[az]){
case 32://space
for(int lol=0;lol<6;lol++)
patterns[az][lol] = dummy_array[26][lol];
case 33://mark
patterns[az][lol] = dummy_array[43][lol];
case 45://line
patterns[az][lol] = dummy_array[41][lol];
case 44://coma
patterns[az][lol] = dummy_array[40][lol];
case 46://dot
patterns[az][lol] = dummy_array[39][lol];
case 47://dvide
patterns[az][lol] = dummy_array[37][lol];
case 48://0
patterns[az][lol] = dummy_array[27][lol];
case 49://1
patterns[az][lol] = dummy_array[28][lol];
case 50://2
patterns[az][lol] = dummy_array[29][lol];
case 51://3
patterns[az][lol] = dummy_array[30][lol];
case 52://4
patterns[az][lol] = dummy_array[31][lol];
case 53://5
patterns[az][lol] = dummy_array[32][lol];
case 54://6
patterns[az][lol] = dummy_array[33][lol];
case 55://7
patterns[az][lol] = dummy_array[34][lol];
case 56://8
patterns[az][lol] = dummy_array[35][lol];
case 57://9
patterns[az][lol] = dummy_array[36][lol];
case 58://tow dots
patterns[az][lol] = dummy_array[38][lol];
case 63://quastion
patterns[az][lol] = dummy_array[42][lol];
default:
display_word(1,patterns,array_turn,15);
array_turn =0;
//display_word(1,patterns,43,15);// calls for the display_pattern function and says that int loop = 15(if you do more loop the pattern whould scrrol slower).
void latchOn(){
bitSet(PORTB,latchPinPORTB);
void latchOff(){
bitClear(PORTB,latchPinPORTB);
void setupSPI(){
byte clr;
SPCR |= ( (1<<SPE) | (1<<MSTR) ); // enable SPI as master
//SPCR |= ( (1<<SPR1) | (1<<SPR0) ); // set prescaler bits
SPCR &= ~( (1<<SPR1) | (1<<SPR0) ); // clear prescaler bits
clr=SPSR; // clear SPI status reg
clr=SPDR; // clear SPI data reg
SPSR |= (1<<SPI2X); // set prescaler bits
//SPSR &= ~(1<<SPI2X); // clear prescaler bits
delay(10);
byte spi_transfer(byte data)
SPDR = data; // Start the transmission
while (!(SPSR & (1<<SPIF))) // Wait the end of the transmission
return SPDR; // return the received byte, we don't need that
