Nevermind guys, I have managed to solve it ...
Here is the code for others who want to scroll their stuff too...
#include <LedControl.h>
#include <ESP8266WiFi.h>
int din = 2, clk = 13, cs = 15;
LedControl lc = LedControl(din, clk, cs, 4);
int devices = lc.getDeviceCount();
char sex = 'm'; //m for male , f for female (To add Mr. OR Mrs. before the name...)
char thename[] = "Aman Dwivedi";
int y = sizeof(thename) / sizeof(byte);
byte plch[92]; // After changing the name , run the program once, use the value of r from the serial monitor (approx. r-7 use trial and error method) and use it as the size of this array...
int r;
const char isSSID[] = "Network";
const char isPass[] = "password";
WiFiServer server(80);
/* All the letters and numbers... */
const byte ch[315] =
B01111100, B10100010, B10010010, B10001010, B01111100, /*0*/
B00100010, B01000010, B11111110, B00000010, B00000010, /*1*/
B01001110, B10001010, B10001010, B10001010, B01111010, /*2*/
B10000100, B10010010, B10110010, B11010010, B10001100, /*3*/
B00011000, B00101000, B01001000, B11111110, B00001000, /*4*/
B11110100, B10010010, B10010010, B10010010, B10001100, /*5*/
B01111100, B10010010, B10010010, B10010010, B01001100, /*6*/
B10000000, B10001110, B10010000, B10100000, B11000000, /*7*/
B01101100, B10010010, B10010010, B10010010, B01101100, /*8*/
B01100100, B10010010, B10010010, B10010010, B01111100, /*9*/
B01111110, B10001000, B10001000, B10001000, B01111110, /*A*/
B11111110, B10000010, B10000010, B10010010, B01101100, /*B*/
B01111100, B10000010, B10000010, B10000010, B01000100, /*C*/
B10000010, B11111110, B10000010, B10000010, B01111100, /*D*/
B11111110, B10010010, B10010010, B10000010, B10000010, /*E*/
B11111110, B10010000, B10010000, B10010000, B10010000, /*F*/
B11111110, B10000010, B10001010, B10001010, B10001110, /*G*/
B11111110, B00010000, B00010000, B00010000, B11111110, /*H*/
B10000010, B10000010, B11111110, B10000010, B10000010, /*I*/
B10001110, B10000010, B11111110, B10000000, B10000000, /*J*/
B11111110, B00010000, B00101000, B01000100, B10000010, /*K*/
B11111110, B00000010, B00000010, B00000010, B00000010, /*L*/
B11111110, B01000000, B00100000, B01000000, B11111110, /*M*/
B11111110, B01000000, B00100000, B00010000, B11111110, /*N*/
B01111100, B10000010, B10000010, B10000010, B01111100, /*O*/
B01111110, B10010000, B10010000, B10010000, B01100000, /*P*/
B01111100, B10000010, B10000010, B10000010, B01111101, /*Q*/
B11111110, B10010000, B10001000, B10010100, B01100010, /*R*/
B01100100, B10010010, B10010010, B10010010, B01001100, /*S*/
B10000000, B10000000, B11111110, B10000000, B10000000, /*T*/
B11111100, B00000010, B00000010, B00000010, B11111100, /*U*/
B11111000, B00000100, B00000010, B00000100, B11111000, /*V*/
B11111110, B00000100, B00001000, B00000100, B11111110, /*W*/
B11100110, B00101000, B00010000, B00101000, B11100110, /*X*/
B11100100, B00010010, B00010010, B00010010, B11111100, /*Y*/
B11000110, B10001010, B10010010, B10100010, B11000110, /*Z*/
B00101110, B00101010, B00111110, B00000010, B00000000, /*a*/
B11111110, B00010010, B00010010, B00001100, B00000000, /*b*/
B00111110, B00100010, B00100010, B00100010, B00000000, /*c*/
B00011110, B00010010, B00010010, B11111110, B00000000, /*d*/
B00111110, B00101010, B00101010, B00111010, B00000000, /*e*/
B00010000, B11111110, B10010000, B10010000, B11000000, /*f*/
B00011010, B00101001, B00101001, B00011110, B00100000, /*g*/
B11111110, B00010000, B00010000, B00001110, B00000000, /*h*/
B00000010, B01011110, B00000010, B00000000, B00000000, /*i*/
B00000110, B00000001, B01011110, B00000000, B00000000, /*j*/
B11111110, B00001000, B00010100, B00100010, B00000000, /*k*/
B11111110, B00000000, B00000000, B00000000, B00000000, /*l*/
B00111110, B00010000, B00011000, B00010000, B00011110, /*m*/
B00100000, B00111110, B00010000, B00011110, B00000000, /*n*/
B00011100, B00100010, B00100010, B00011100, B00000000, /*o*/
B00111111, B00010100, B00011100, B00000000, B00000000, /*p*/
B00011100, B00010100, B00111111, B00000001, B00000000, /*q*/
B00111110, B00010000, B00100000, B00100000, B00000000, /*r*/
B00011010, B00101010, B00101010, B00101100, B00000000, /*s*/
B00100000, B11111100, B00100010, B00000100, B00000000, /*t*/
B00111100, B00000010, B00000010, B00111100, B00000010, /*u*/
B00111000, B00000100, B00000010, B00000100, B00111000, /*v*/
B00111100, B00000010, B00000100, B00000010, B00111100, /*w*/
B00100010, B00010100, B00001000, B00010100, B00100010, /*x*/
B00111001, B00001001, B00001001, B00111111, B00000000, /*y*/
B00100110, B00101010, B00110010, B00100010, B00000000, /*z*/
B00000000, B00000000, B00000000, /* */
B00000010 /*.*/
const byte divider = {B11111111};
int initloc(char x) { //works
int location;
if (x >= '0' && x <= '9') location = 5 * (x - 48) ;
if (x >= 'A' && x <= 'Z') location = 5 * (x - 65) + 50 ;
if (x >= 'a' && x <= 'z') location = 5 * (x - 97) + 180 ;
if (x == ' ') location = 310 ;
if (x == '.') location = 313 ;
return location;
byte make(char c, int i) { //works
byte x;
int loc = initloc(c);
x = ch[loc + i];
return x;
void stationary(char x, char y) { //works
for (int i = 2; i < 4; i++)
lc.setColumn(1, i, divider);
lc.setColumn(1, 4, 0);
byte pholder[12];
for (int i = 0; i < 5; i++)
pholder[i] = make(x, i);
pholder[5] = B00000000;
pholder[i + 6] = make(y, i);
for (int i = 5; i < 8; i++)
lc.setColumn(1, i, pholder[i - 5]);
for (int i = 0; i < 8; i++)
lc.setColumn(0, i, pholder[i + 3]);
void onehelp(char curchar , int i) {
int w;
for (w = 0; w < i; w++) {
plch[w + r] = make(curchar, w);
plch[i + r] = B00000000;
Serial.print(" ");
Serial.print(plch[w + r]);
void makeplaceholder() {
for (int x = 0; x < y; x++) {
char curchar = thename[x];
if (curchar == ' ') {
onehelp(curchar, 2);
r += 3;
else if (curchar == 'a' || curchar == 'b' || curchar == 'c' || curchar == 'd' || curchar == 'e' || curchar == 'h' || curchar == 'k' || curchar == 'n' || curchar == 'o' || curchar == 'q' || curchar == 'r' || curchar == 's' || curchar == 't' || curchar == 'y' || curchar == 'z') {
onehelp(curchar, 5);
r += 5;
else if (curchar == 'i' || curchar == 'j' || curchar == 'p') {
r += 4;
else if (curchar == 'l') {
r += 2;
else if (curchar != ' ' && curchar != '.') {
r += 6;
else {
onehelp(curchar, 1);
r += 2;
Serial.print("r is : ");
Serial.print(r);
void scroll() {
int w = sizeof(plch) / sizeof(byte);
byte zhelp;
zhelp = plch[0];
for (int i = 0; i < 2; i++)
lc.setColumn(1, i, plch[i + 16]);
for (int j = 0; j < 8; j++)
lc.setColumn(2, j, plch[j + 8]);
for (int k = 0; k < 8; k++)
lc.setColumn(3, k, plch[k]);
delay(75);
for (int q = 0; q < w; q++)
plch[q] = plch[q + 1];
plch[w] = zhelp;
void initHardware() {
for (int i = 0 ; i < devices ; i++) {
lc.shutdown(i, false);
lc.setIntensity(i, 0);
lc.clearDisplay(i) ;
Serial.println("Started...");
for (int l = 0; l < 18; l++)
plch[l] = B00000000;
byte secm[] = {B11111110, B01000000, B00100000, B01000000, B11111110, B00000000, B00111110, B00010000, B00100000, B00100000, B00000010, B00000000, B00000000, B00000000};
byte secf[] = {B11111110, B01000000, B00100000, B01000000, B11111110, B00000000, B00111110, B00010000, B00100000, B00100000, B00000000, B00011010, B00101010, B00101010, B00101100, B00000000, B00000010, B00000000, B00000000, B00000000};
if (sex == 'm') {
for (int h = 0; h < 14; h++)
plch[18 + h] = secm[h];
r = 32;
else if (sex == 'f') {
for (int h = 0; h < 20; h++)
plch[18 + h] = secf[h];
r = 38;
makeplaceholder();
void increment() {
initHardware();
scroll();
stationary('0','0');
