qazrix
September 6, 2017, 11:39am
1
When i make darkness only pin 7 works
int lightPin = 0; //define a pin for Photo resistor
int ledPin1 = 5;
int ledPin2 = 6;
int ledPin3 = 7;
void setup(){
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
void loop(){
int lectura = analogRead(lightPin);
if(lectura < 500)
digitalWrite(ledPin1, LOW);
digitalWrite(ledPin2, LOW);
digitalWrite(ledPin3, LOW);
else if(lectura >= 500 && lectura < 300)
digitalWrite(ledPin1, HIGH);
else if(lectura >= 500 && lectura < 500)
digitalWrite(ledPin2, HIGH);
else if(lectura >= 700)
digitalWrite(ledPin3, HIGH);
delay(100);
God will be most upset with you.
so how can this variable be above 500 and below 300 at the same time?
and how can this variable be above 500 and below 500 at the same time?
vaj4088
September 6, 2017, 10:42pm
3
Also, this is a bad idea:
Pins 0 and 1 are generally used on Arduinos by the serial port for debugging and for code downloading. I am not saying that Pins 0 and 1 can't be used if handled carefully, but otherwise I would suggest that you choose a different pin .
Wawa
September 7, 2017, 1:11am
4
vaj4088:
... analogRead(lightPin); // the compiler switches here to A0
int lightPin = 0; // bad practice if you mean the analogue pin
int lightPin = A0; // better
Leo..
vaj4088
September 7, 2017, 2:45am
5
I didn't know that about analogRead(). Thanks!
