LEDs are shining bad
Hi!
I have a problem.
On my Arduino MEGA 2560, LEDs are on HIGH power on DIGITAL pin shining very bad.
In the past they all worked perfect.
I do not know what to do.
Please if u know anything write me under the topis or on vitodro@gmail.com
TNX
You of course always use a series resistor with each LED.
Show us an image of your wiring.
You got the pins set as output with pinmode?
In response to your pm, I mean have you used pinMode to set each pin as an output?
Read the NOTE on this reference page.
pinMode(10, OUTPUT)  //edit.... I typed this above setup() earlier sorry
digitalWrite(10, HIGH)
void loop() {}
JimboZA:
pinMode(10, OUTPUT)
void loop() {}
Yes, here is the program:
int sensorValue = analogRead(A0);
float voltage = sensorValue * (5.0 / 1023.0);
Serial.println(voltage);
if (voltage<1) digitalWrite(52, HIGH);
if (voltage>1) digitalWrite(52, LOW);
if (voltage<1) digitalWrite(42, LOW);
if (voltage>1, voltage<4) digitalWrite(42, HIGH);
if (voltage>4) digitalWrite(42, LOW);
if (voltage>4) digitalWrite(30, HIGH);
if (voltage<4) digitalWrite(30, LOW);
There's no pinMode line in that code.
The note I linked to, specifically says an LED will be dull if you don't use pinMode to make the pin an output.
What to do then?
But LEDs are shining, just so badly, that it is useless.
vitothelegend:
What to do then?
Add pinMode commands into your code, one for each in that you use like 52 and 42, inside setup() like this:
pinMode(42, OUTPUT);
pinMode(52, OUTPUT);
// and for any other pin with an led connected
this just appeard as an error:
enabled in File > Preferences.
Arduino: 1.0.6 (Windows NT (unknown)), Board: "Arduino Mega 2560 or Mega ADK"
Velikost binarne skice: 6.584 bajtov (od 258.048 možnih bajtov)
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: ser_send(): write error: sorry no info avail
Thanks you very much.
It is working now.
