LED's doesn't light up with digital output
I have attached an image of the setup, here is a schematic view:
/*  TRS= 220 Ohm Transistor, LED = Light Emitting Diode, GND = ground
        ______________
        |          13|-TRS---LED---|
        |          12|-TRS---LED---|
        |          11|-TRS---LED---|
        |          10|-TRS---LED---|
        |           9|-TRS---LED---|
        |           8|-TRS---LED---|
        |           6|-TRS---LED---|
        |           5|-TRS---LED---|
        |           4|-TRS---LED---|
        |           3|-TRS---LED---|
        |           2|-TRS---LED---|
        |           1|             |
        |   GND     0|             |
I had some trouble with an LED that lit up no matter what I did, so I decided to test the boards digital outputs, now I can't get any of the LED's to light up. As you can see in my code below, I first set alle the pins from 2-13 to OUTPUT. In loop() I check whether a boolean is true or false, set all the pins to HIGH if it is and to LOW if it's not. At the end of loop() I change the state of the boolean before delay()-ing a quarter of a second. As you can see from the image, none of the LED's light up. Here is my code:
boolean on = true;
  for (int i = 2; 1 < 13; i++) {
    pinMode(i, OUTPUT);
  if (!on) {
    for (int i = 2; i < 13; i++) {
      digitalWrite(i, LOW);
  if (on) {
      digitalWrite(i, HIGH);
  on != on;
  delay(250);
EDIT: Changed the code, removed an extra "}" and "pinmode(2,INPUT)", as it was not supposed to be part of the code.
That code doesn't compile so that's why it doesn't work.
Anyway why is pin 2 set to output and then immediately changed to input?
Steve
Sorry, I had some mistakes in there after I tried to debug. I changed the code, to how it was when I first tried it, and I still get the same result.
But if I run this code, LED's connected to pins 8,12 and 13 light up:
boolean on = true;
    pinMode(i, OUTPUT);
  if (on) {
  on != on;
  delay(250);
for (int i = 2; 1 < 13; i++)One is always less than thirteen
 on != on;
You need on = !on;
