I managed to get my LED’s hooked up and programmed to separate pins than what my switches are (switches on pins 3, 4, 5, 6 - LEDs on 8, 9, 10, 11) but I want the led to stay off when I hit the switch(es) once, and come on again when I hit the switch(es) a second time - like an indicator light to let me know that my parameter is active or not. I have searched for hours and tried several different things… buttonstates, flipflop commands a bunch of other stuff. I can’t seem to code this! Any ideas? Here is my code so far:
#include <MIDI.h>
#include "Controller.h"
MIDI_CREATE_DEFAULT_INSTANCE();
byte NUMBER_BUTTONS = 4;
byte NUMBER_POTS = 0;
byte NUMBER_MUX_BUTTONS = 0;
byte NUMBER_MUX_POTS = 0;
Pot *POTS[] {};
//***DEFINE DIRECTLY CONNECTED BUTTONS*******************************
//Button (Pin Number, Command, Note Number, Channel, Debounce Time)
//** Command parameter 0=NOTE 1=CC 2=Toggle CC **
Button BU1(3, 2, 28, 1, 5 );
Button BU2(4, 2, 36, 1, 5 );
Button BU3(5, 2, 50, 1, 5 );
Button BU4(6, 1, 64, 1, 5 );
Button *BUTTONS[] {&BU1, &BU2, &BU3, &BU4};
Button *MUXBUTTONS[] {};
Pot *MUXPOTS[] {};
int ledpin1 = 8;
int ledpin2 = 9;
int ledpin3 = 10;
int ledpin4 = 11;
int pushbutton1 = 3;
int pushbutton2 = 4;
int pushbutton3 = 5;
int pushbutton4 = 6;
int buttonState = 0;
static bool ledState = false; // LED is off by default
MIDI.begin(MIDI_CHANNEL_OFF);
pinMode(ledpin1,OUTPUT);
pinMode(ledpin2,OUTPUT);
pinMode(ledpin3,OUTPUT);
pinMode(ledpin4,OUTPUT);
pinMode(pushbutton1,INPUT_PULLUP); // Provide pullup
pinMode(pushbutton2,INPUT_PULLUP); // Provide pullup
pinMode(pushbutton3,INPUT_PULLUP); // Provide pullup
pinMode(pushbutton4,INPUT_PULLUP); // Provide pullup
if (NUMBER_BUTTONS != 0) updateButtons();
if (NUMBER_POTS != 0) updatePots();
if (NUMBER_MUX_BUTTONS != 0) updateMuxButtons();
if (NUMBER_MUX_POTS != 0) updateMuxPots();
if((digitalRead(pushbutton1) == LOW) && ledState) // led is off when parameter deactivated
delay(10); // wait for 10 ms
digitalWrite(ledpin1, LOW);
ledState = false;
if((digitalRead(pushbutton1) == LOW) && !ledState) // led is on when parameter is activated
digitalWrite(ledpin1, HIGH);
delay(50); // wait for 50 ms
ledState = true;
void updateButtons() {
// Cycle through Button array
for (int i = 0; i < NUMBER_BUTTONS; i = i + 1) {
byte message = BUTTONS[i]->getValue();
// Button is pressed
if (message == 0) {
switch (BUTTONS[i]->Bcommand) {
case 0: //Note
MIDI.sendNoteOn(BUTTONS[i]->Bvalue, 127, BUTTONS[i]->Bchannel);
case 1: //CC
MIDI.sendControlChange(BUTTONS[i]->Bvalue, 127, BUTTONS[i]->Bchannel);
case 2: //Toggle
if (BUTTONS[i]->Btoggle == 0) {
BUTTONS[i]->Btoggle = 1;
else if (BUTTONS[i]->Btoggle == 1) {
MIDI.sendControlChange(BUTTONS[i]->Bvalue, 0, BUTTONS[i]->Bchannel);
BUTTONS[i]->Btoggle = 0;
// Button is not pressed
if (message == 1) {
case 0:
MIDI.sendNoteOff(BUTTONS[i]->Bvalue, 0, BUTTONS[i]->Bchannel);
case 1:
void updateMuxButtons() {
// Cycle through Mux Button array
for (int i = 0; i < NUMBER_MUX_BUTTONS; i = i + 1) {
MUXBUTTONS[i]->muxUpdate();
byte message = MUXBUTTONS[i]->getValue();
if (message == 0) {
switch (MUXBUTTONS[i]->Bcommand) {
case 0: //Note
MIDI.sendNoteOn(MUXBUTTONS[i]->Bvalue, 127, MUXBUTTONS[i]->Bchannel);
case 1: //CC
MIDI.sendControlChange(MUXBUTTONS[i]->Bvalue, 127, MUXBUTTONS[i]->Bchannel);
case 2: //Toggle
if (MUXBUTTONS[i]->Btoggle == 0) {
MUXBUTTONS[i]->Btoggle = 1;
else if (MUXBUTTONS[i]->Btoggle == 1) {
MIDI.sendControlChange(MUXBUTTONS[i]->Bvalue, 0, MUXBUTTONS[i]->Bchannel);
MUXBUTTONS[i]->Btoggle = 0;
if (message == 1) {
case 0:
MIDI.sendNoteOff(MUXBUTTONS[i]->Bvalue, 0, MUXBUTTONS[i]->Bchannel);
case 1:
void updatePots() {
for (int i = 0; i < NUMBER_POTS; i = i + 1) {
byte potmessage = POTS[i]->getValue();
if (potmessage != 255) MIDI.sendControlChange(POTS[i]->Pcontrol, potmessage, POTS[i]->Pchannel);
void updateMuxPots() {
for (int i = 0; i < NUMBER_MUX_POTS; i = i + 1) {
MUXPOTS[i]->muxUpdate();
byte potmessage = MUXPOTS[i]->getValue();
if (potmessage != 255) MIDI.sendControlChange(MUXPOTS[i]->Pcontrol, potmessage, MUXPOTS[i]->Pchannel);
I think the relevant section is in the void loop. Any ideas?
