Created a Server Room Project I though I would share.
Project tests temperature (*F) and will flash addressable LED Strip according to different alarms. Project will also turn on all LEDs to White if someone enters server room for more light.
I borrowed from a lot of different projects, so thank you all for your help.
JP
* Project: Server Room Temperature and Person Detection
* Created by Jared Pruett
* Board: Ardunio Uno
* PIR Sensor: HC-SR501
* Thermostat: DS17B20
* LEDS: 5M / 16.4Ft LED Strip - WS2812B - 300 Pixels on LED Strip and 5V 15amp Power supply
* Description:
* PIR sensor checks if people enter room and turns on White Lights to see better
* Temperature is checked constantly and will alarm the LEDs (Red and White for Hot, Blue and White for Cold)
* Pin Out:
* D2: PIR Sensor
* D3: Thermostat
* D4: Buzzer
* D7: LED Signal Line
#include <FastLED.h>
#include <OneWire.h>
#include <DallasTemperature.h>
//ONE WIRE and Temperature Sensor
// Data wire is conntec to the Arduino digital pin 3
#define ONE_WIRE_BUS 3
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature sensor
DallasTemperature sensors(&oneWire);
//LED Stuff
#define LED_PIN 7
#define NUM_LEDS 300
CRGB leds[NUM_LEDS];
//Pins Number Setup
int motionSensorPin = 2;
int thermostatPin = 3;
int buzzerPin = 4;
//Intial Variables
int curTemp = 72;
int alarmTimeDelay = 500;
int OnOffDelay = 60000; //Motion Delay
FastLED.addLeds<WS2812, LED_PIN, GRB>(leds, NUM_LEDS);
Serial.begin(9600); // setup Serial Monitor to display information
pinMode(motionSensorPin, INPUT); // Input from motion sensor
pinMode(thermostatPin, INPUT); // Input from thermostat
pinMode(buzzerPin, OUTPUT); // Output from buzzer
sensors.begin(); //Start Checking Temp
digitalWrite(4,LOW); //Cut of Buzzer
// Function to Turn on White Light
void lightsOn()
for(int LED=0;LED<NUM_LEDS;LED++)
leds[LED]=CRGB(255,255,255);
FastLED.show();
delay(OnOffDelay);
// Function to Turn off All Light
void lightsOff()
leds[LED]=CRGB(0,0,0);
FastLED.show();
//Function to Flash RGB Color Specified, alternating Colr and White
void alarmLED (int red, int green, int blue)
if (LED % 2 == 0)
leds[LED]=CRGB(red,green,blue);
FastLED.show();
delay(alarmTimeDelay);
if (LED % 2 == 0)
FastLED.show();
// Function to check temperature and determine what to do when temperature reaches hiTemp and loTemp Settings.
void tempCheck(int temp)
int hiTemp = 90;
int loTemp = 55;
if (temp < loTemp)
alarmLED(0,0,255); //Flash LEDS Blue
buzzer (1);
else if (temp > hiTemp)
alarmLED(255,0,0); //Flash LEDs Red
buzzer (1);
//Turn off Buzzer and Serial Print the Current Temperature
buzzer (0);
Serial.print("Current Temperature: ");
Serial.print(temp );
Serial.print(" *F");
//Turn on Buzzer (1 for On, 0 for Off)
void buzzer(int buzz)
if (buzz == 1)
digitalWrite(4,HIGH);
int motion = digitalRead(motionSensorPin);
if(motion)
Serial.println("Motion detected - Turning on Lights");
lightsOn();
lightsOff();
// Call sensors.requestTemperatures() to issue a global temperature and Requests to all devices on the bus
sensors.requestTemperatures();
curTemp = sensors.getTempFByIndex(0);
tempCheck (curTemp);
