Hi guys,
I'm quite confused. I've been trying to solve this for quite a while now and have gotten nowhere. The wiring on my breadboard is correct and all the pins are wired correctly.
My serial monitor shows that the joystick is working as it is outputting the x and y values. However, the LED's won't light up. They do work outside of this circuit, as I've tried them all individually.
I'm now wondering if I have missed something blindingly obvious in my code that I can't see as I've been looking at it for so long now!
I am using a MEGA2560 for your reference. No errors are coming up too.
//Program to control what LED lights up in a circle that is controlled by a
//joystick. If the joystick is pressed down, all LEDs flash. Default mode is all
//LEDs are off when the joystick is in a neutral position.
int SW_pin = 2; // Digital pin connected to switch output
int X_pin = 0; // Analog pin connected to X output
int Y_pin = 1; // Analog pin connected to Y output
int N_LED_Pin=4; // Declaring N_LED_Pin as a variable to pin
int E_LED_Pin=5; // Declaring N_LED_Pin as a variable to pin
int S_LED_Pin=6; // Declaring N_LED_Pin as a variable to pin
int W_LED_Pin=7; // Declaring N_LED_Pin as a variable to pin
pinMode(SW_pin, INPUT);
digitalWrite(SW_pin,HIGH);
pinMode(N_LED_Pin, OUTPUT);
pinMode(E_LED_Pin, OUTPUT);
pinMode(S_LED_Pin, OUTPUT);
pinMode(W_LED_Pin, OUTPUT);
if ((analogRead(X_pin)<550) && (analogRead(X_pin)>400) && (analogRead(Y_pin)<550) && (analogRead(Y_pin)>400)) {
analogWrite(N_LED_Pin,0); // Setting N_LED_Pin off
analogWrite(E_LED_Pin,0); // Setting E_LED_Pin off
analogWrite(S_LED_Pin,0); // Setting S_LED_Pin off
analogWrite(W_LED_Pin,0); // Setting W_LED_Pin off
if ((analogRead(X_pin)<100) && (analogRead(Y_pin)<550) && (analogRead(Y_pin)>400)) {
analogWrite(N_LED_Pin,100); // Setting the brightness of N_LED_Pin high
if ((analogRead(Y_pin)<100) && (analogRead(X_pin)<550) && (analogRead(X_pin)>400)) {
analogWrite(E_LED_Pin,100); // Setting the brightness of E_LED_Pin high
if ((analogRead(X_pin)>550) && (analogRead(Y_pin)<550) && (analogRead(Y_pin)>400)) {
analogWrite(S_LED_Pin,100); // Setting the brightness of S_LED_Pin high
if ((analogRead(Y_pin)>550) && (analogRead(X_pin)<550) && (analogRead(X_pin)>400)) {
analogWrite(W_LED_Pin,100); // Setting the brightness of W_LED_Pin high
if (digitalRead(SW_pin) == LOW) {
Serial.print("Switch: ");
Serial.print(digitalRead(SW_pin));
Serial.print("\n");
Serial.print("X-axis: ");
Serial.print(analogRead(X_pin));
Serial.print("\n");
Serial.print("Y-axis: ");
Serial.println(analogRead(Y_pin));
Serial.print("\n\n");
