LEDs wont cycle through modes (ws2801)
Ive been learning arduino over the past year and am sincerly stumped by this little issue. I have a momentary switch hooked up to two WS2801 breakouts and i cant get a switch to cycle through. I really thought this was it but alas i am STUMPED! Any help would rock!
#include "SPI.h"
#include "WS2801.h"
    int buttonPin = 4;    // momentary push button on pin 4
    int oldButtonVal = 0;
    int dataPin = 2;
    int clockPin = 3;
   WS2801 strip = WS2801(2, dataPin, clockPin);
    int nPatterns = 3;
    int lightPattern = 1;
// the setup routine runs once when you press reset:
    strip.begin();
    strip.show();                // initialize all pixels to 'off'
// initialize the BUTTON pin as an input
    pinMode(buttonPin, INPUT);
    digitalWrite(buttonPin, HIGH);  // button pin is HIGH, so it drops to 0 if pressed
// Pattern 1 - White light, all LEDs in the strip are white
    void pattern1() {
        strip.setPixelColor(0,(190,0,60));
        strip.setPixelColor(1,(100,190,00));
    strip.show();
// Pattern 2 - Red light, all LEDs in the strip are red
    void pattern2() {
        strip.setPixelColor(0,(255, 100, 0)); // Red
        strip.setPixelColor(1,(0, 111, 0));
    strip.show();
    void pattern3() {
        strip.setPixelColor(0,(255, 255, 255)); // Red
        strip.setPixelColor(1,(199, 111, 9));
    strip.show();
// the loop routine runs over and over again forever;
  // read that state of the pushbutton value;
  int buttonVal = digitalRead(buttonPin);
  if (buttonVal == LOW && oldButtonVal == HIGH) {// button has just been pressed
    lightPattern = lightPattern + 1;
  if (lightPattern > nPatterns) lightPattern = 1;
  oldButtonVal = buttonVal++;
  switch(lightPattern) {
    case 1:
      pattern1();
    case 2:
      pattern2();
      case 3:
      pattern3();
[code/]
What is the purpose of this?
The 'previous' button value is not the current value plus one... the value you want to store for the next time around is the current value! So, I think it should be...
  oldButtonVal = buttonVal;
Hmm, def true. It didnt fix the code though :frowning:
Please be more specific then. I think I know what you expect to happen, but please say what actually happens.
Also, you don't need to check the value of "lightPattern" for overflow when you haven't changed it, so I would restructure the block this way...
    lightPattern++;
Thank you. the first LED of the Strip i made stays blue and the second does nothing. The button also yields no response. Once again to explain in the best way possible.
I want to press the button and each time have it cycle through a different predetermined set of 2 colors before it eventually is back to off.
Sounds like you might have multiple hardware issues. Can you post a diagram or something?
I totaly fixed it by mixing it with another code i found. The only thing it wont do is start on the off position…why is this?
#include "SPI.h"
#include "WS2801.h"
const int buttonPin = 4;     // the number of the pushbutton pin
int dataPin = 2;
int clockPin = 3;
int nPatterns = 4;
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
// Don't forget to connect the ground wire to Arduino ground,
// and the +5V wire to a +5V supply
// Set the first variable to the NUMBER of pixels. 25 = 25 pixels in a row
// Optional: leave off pin numbers to use hardware SPI
// (pinout is then specific to each board and can't be changed)
//WS2801 strip = WS2801(25);
    strip.begin();
  // initialize the pushbutton pin as an input:
  // Update LED contents, to start they are all 'off'
  // Some example procedures showing how to display to the pixels
   // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
    case 1:
      pattern1();
    case 2:
      pattern2();
      case 3:
      pattern3();
    case 4:
      pattern4();
}void pattern1() {
     strip.setPixelColor(0, Color(255,77,255));
     strip.setPixelColor(1, Color(144,0,6));
     strip.show();   // write all the pixels out
  } void pattern2() {
     strip.setPixelColor(0, Color(255,0,255));
     strip.setPixelColor(1, Color(0,0,255));
  }  void pattern3() {
     strip.setPixelColor(0, Color(0,255,255));
     strip.setPixelColor(1, Color(100,0,255));
  }  void pattern4() {
     strip.setPixelColor(0, Color(0,255,0));
     strip.setPixelColor(1, Color(100,255,255));
void rainbow(uint8_t wait) {
  int i, j;
  for (j=0; j < 256; j++) {     // 3 cycles of all 256 colors in the wheel
    for (i=0; i < strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel( (i + j) % 255));
    delay(wait);
// Slightly different, this one makes the rainbow wheel equally distributed
// along the chain
void rainbowCycle(uint8_t wait) {
  int i, j;
  for (j=0; j < 256 * 5; j++) {     // 5 cycles of all 25 colors in the wheel
      // tricky math! we use each pixel as a fraction of the full 96-color wheel
      // (thats the i / strip.numPixels() part)
      // Then add in j which makes the colors go around per pixel
      // the % 96 is to make the wheel cycle around
      strip.setPixelColor(i, Wheel( ((i * 256 / strip.numPixels()) + j) % 256) );
    delay(wait);
// fill the dots one after the other with said color
// good for testing purposes
void colorWipe(uint32_t c, uint8_t wait) {
  int i;
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
/* Helper functions */
// Create a 24 bit color value from R,G,B
uint32_t Color(byte r, byte g, byte b)
  uint32_t c;
  c = r;
  c <<= 8;
  c |= g;
  c <<= 8;
  c |= b;
  return c;
//Input a value 0 to 255 to get a color value.
//The colours are a transition r - g -b - back to r
uint32_t Wheel(byte WheelPos)
  if (WheelPos < 85) {
    return Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  else if (WheelPos < 170) {
    WheelPos -= 85;
    return Color(255 - WheelPos * 3, 0, WheelPos * 3);
  else {
    WheelPos -= 170;
    return Color(0, WheelPos * 3, 255 - WheelPos * 3);
[code/]
Well, you have programmed it to start with light pattern 1. You don’t have an “off” pattern. You should create that as pattern 1.
PERFECT!!!! Done Thank you!!!
