left right crnter game
i’m trying to create a left, center, right game using a lcd keypad shield, i’ve tried or, xor, and, every bite-wise operator that would make sense in the game, it’s ether the rolling code or the if statments
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int randNumber = 0;
    // define some values used by the panel and buttons
    int lcd_key     = 0;
    int adc_key_in  = 0;
  #define btnRIGHT  0
  #define btnUP     1
  #define btnDOWN   2
  #define btnLEFT   3
  #define btnSELECT 4
  #define btnNONE   5
    // read the buttons
    int read_LCD_buttons() {
      adc_key_in = analogRead(0);      // read the value from the sensor
      // my buttons when read are centered at these valies: 0, 144, 329, 504, 741
      // we add approx 50 to those values and check to see if we are close
      //if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
      // For V1.1 us this threshold
      if (adc_key_in > 1000) { return btnNONE; }
      // For V1.0 comment the other threshold and use the one below:
      if (adc_key_in < 50)   { return btnRIGHT; }
      if (adc_key_in < 195)  { return btnUP; }
      if (adc_key_in < 380)  { return btnDOWN; }
      if (adc_key_in < 555)  { return btnLEFT; }
      if (adc_key_in < 790)  { return btnSELECT; }
      return btnNONE;  // when all others fail, return this...
  lcd.begin(16, 2);              // start the library
  lcd.setCursor(0, 0);
  lcd.print("press select to dice"); // print a simple message
  randomSeed (analogRead (1));
void loop(){
int diceOne = random (1,4);
int diceTwo = random (1,4);
int diceThree = random (1,4);
int R;
int L;
int C;
lcd_key = read_LCD_buttons();  // read the buttons
    if(lcd_key == btnSELECT) {
        lcd.clear();
        lcd.setCursor(2, 0);
        lcd.print(diceOne);
        lcd.setCursor(8, 0);
        lcd.print(diceTwo);
        lcd.setCursor(14,0);
        lcd.print(diceThree);
        analogRead(lcd_key == btnSELECT);
        delay(100);
        delay(100);
  if (diceOne == 3 || diceTwo == 3 || diceThree == 3) {
   // if diceOne is 3 or diceTwo is 3 or diceTree is 3
    // instead of
    // if diceOne or diceTwo or diceTree is 3
  lcd.setCursor (2,0);
  lcd.print("R");
  if (diceOne == 2 || diceTwo == 2 || diceThree == 2) {
    // if diceOne is 2 or diceTwo is 2 or diceTree is 2
    // instead of
    // if diceOne or diceTwo or diceTree is 2
    lcd.setCursor(8,0);
    lcd.print ("C");
  if (diceOne == 1 || diceTwo == 1 || diceThree == 1) {
    // if diceOne is 1 or diceTwo is 1 or diceTree is 1
    // instead of
    // if diceOne or diceTwo or diceTree is 1
    lcd.print ("C");
Someone explain to this person about arrays.
