hello everyone , i already ask for help about type of monochrome LCDS 160x160 "i have a lot of them maybe 10 pcs or more , on this topic
i forget that for a moment , i use an olimex project zip file , i extract the lcd library files "Lcd.h" and "lcd.c" because is use the same lcd on project named (TLCD_128CAN)
i modified the whole library to be adaptable with arduino platform , the problem is the expansive Ram by the library , i doesn't have huge understanding about the library codding i got some help from (AI
)about the stricture of writing library he get me skeleton code , the libray CPP file is :
#include "PC1681WE05.h"
#include "font_8x8.h"
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/pgmspace.h>
extern unsigned char bitmap[160 * 20];
#define lcd_delay 100 //30534 - old
#define CP_PIN 0
#define DISP_PIN 1
#define VHH_PIN 2
#define LP_PIN 3
#define FLM_PIN 4
#define D3_PIN 5
#define D2_PIN 6
#define D1_PIN 7
#define D0_PIN 8
#define EL2_PIN 9
#define EL1_PIN 10
#define EN_PIN 11
#define EN_OFF digitalWrite(EN_PIN, LOW)
#define EN_ON digitalWrite(EN_PIN, HIGH)
#define DISP_OFF digitalWrite(DISP_PIN, LOW)
#define DISP_ON digitalWrite(DISP_PIN, HIGH)
#define VHH_OFF digitalWrite(VHH_PIN, LOW)
#define VHH_ON digitalWrite(VHH_PIN, HIGH)
#define LP_LOW digitalWrite(LP_PIN, LOW)
#define LP_HIGH digitalWrite(LP_PIN, HIGH)
#define FLM_LOW digitalWrite(FLM_PIN, LOW)
#define FLM_HIGH digitalWrite(FLM_PIN, HIGH)
#define D3_LOW digitalWrite(D3_PIN, LOW)
#define D3_HIGH digitalWrite(D3_PIN, HIGH)
#define D2_LOW digitalWrite(D2_PIN, LOW)
#define D2_HIGH digitalWrite(D2_PIN, HIGH)
#define D1_LOW digitalWrite(D1_PIN, LOW)
#define D1_HIGH digitalWrite(D1_PIN, HIGH)
#define D0_LOW digitalWrite(D0_PIN, LOW)
#define D0_HIGH digitalWrite(D0_PIN, HIGH)
#define EL2_LOW digitalWrite(EL2_PIN, LOW)
#define EL2_HIGH digitalWrite(EL2_PIN, HIGH)
#define EL1_LOW digitalWrite(EL1_PIN, LOW)
#define EL1_HIGH digitalWrite(EL1_PIN, HIGH)
#define EN_LOW digitalWrite(EN_PIN, LOW)
#define EN_HIGH digitalWrite(EN_PIN, HIGH)
PC1681WE05::PC1681WE05() {
pinMode(CP_PIN, OUTPUT);
pinMode(DISP_PIN, OUTPUT);
pinMode(VHH_PIN, OUTPUT);
pinMode(LP_PIN, OUTPUT);
pinMode(FLM_PIN, OUTPUT);
pinMode(D3_PIN, OUTPUT);
pinMode(D2_PIN, OUTPUT);
pinMode(D1_PIN, OUTPUT);
pinMode(D0_PIN, OUTPUT);
pinMode(EL2_PIN, OUTPUT);
pinMode(EL1_PIN, OUTPUT);
pinMode(EN_PIN, OUTPUT);
void PC1681WE05::initLCD() {
// Initialize LCD controler
DISP_OFF;
VHH_OFF;
LP_LOW;
FLM_LOW;
D3_LOW;
D2_LOW;
D1_LOW;
D0_LOW;
EL2_LOW;
EL1_LOW;
void PC1681WE05::lcdOn() {
volatile unsigned int i = 0;
// delay
for(i=0; i<65534; i++);
EN_ON;
// delay 30534 - old
for (i = 0; i < lcd_delay; i++)
VHH_ON;
// delay
DISP_ON;
// delay
void PC1681WE05::lcdOff() {
// delay
DISP_OFF;
// delay
VHH_OFF;
// delay
EN_OFF;
// delay
for (i = 0; i < 65534; i++)
void PC1681WE05::setBacklight(unsigned char light) {
switch (light) {
case 0:
EL1_LOW;
EL2_LOW;
case 1:
EL1_LOW;
EL2_HIGH;
case 2:
EL2_LOW;
EL1_HIGH;
default:
EL1_LOW;
EL2_LOW;
void PC1681WE05::writeBitmap() {
// variable for loop cycle
unsigned int i = 0;
unsigned int j = 0;
// loop for every row
// for(i=20; i<(160*20); i+=20) {
for (i = 0; i < (3200); i += 20) {
// loop for every col
for (j = 0; j < 20; j++) {
// get data
unsigned char pl = bitmap[i + j];
unsigned char ph = pl >> 4;
pl &= 0xF;
//IO0CLR = 0x001E0000;
//IO0SET = LookUpSet[ph];
// clock CP
//IO0CLR = BIT21; - do it with OC1C
//IO0SET = LookUpSet[pl];
// clock CP
if (i) {
LP_HIGH;
LP_LOW;
// start new frame
// for every new frame
FLM_HIGH;
LP_HIGH;
LP_LOW;
FLM_LOW;
LP_HIGH;
LP_LOW;
//Blank screen***************************************************
void PC1681WE05::writeBlank() {
for (int i = 0; i < (3200); i += 20) {
for (int j = 0; j < 20; j++) {
bitmap[i + j] = 0;
// Write char to LCD at specify position
// x, y is coordinate
// invert is 0 or 1 - invert text
void PC1681WE05::writeChar(int x, int y, char ch, bool invert) {
#if 0
PGM_P p;
switch(nmb){
case 0: memcpy_P(myrow[pos], &FontLookup[ch-32][0], 8);
case 1: memcpy_P(myrow2[pos], &FontLookup[ch-32][0], 8);
case 2: memcpy_P(myrow3[pos], &FontLookup[ch-32][0], 8);
case 3: memcpy_P(myrow4[pos], &FontLookup[ch-32][0], 8);
case 4: memcpy_P(myrow5[pos], &FontLookup[ch-32][0], 8);
case 5: memcpy_P(myrow6[pos], &FontLookup[ch-32][0], 8);
case 6: memcpy_P(myrow7[pos], &FontLookup[ch-32][0], 8);
case 7: memcpy_P(myrow8[pos], &FontLookup[ch-32][0], 8);
case 8: memcpy_P(myrow9[pos], &FontLookup[ch-32][0], 8);
case 9: memcpy_P(myrow10[pos], &FontLookup[ch-32][0], 8);
// END of switch
#endif
#if 1
if (!invert) {
memcpy_P(&bitmap[(x + 1) * 20 + y], &FontLookup[ch - 32][0], 1); //bitmap[(x+1)*20+y] = FontLookup[ch-32][0];
memcpy_P(&bitmap[(x + 2) * 20 + y], &FontLookup[ch - 32][1], 1); //bitmap[(x+2)*20+y] = FontLookup[ch-32][1];
memcpy_P(&bitmap[(x + 3) * 20 + y], &FontLookup[ch - 32][2], 1); //bitmap[(x+3)*20+y] = FontLookup[ch-32][2];
memcpy_P(&bitmap[(x + 4) * 20 + y], &FontLookup[ch - 32][3], 1); //bitmap[(x+4)*20+y] = FontLookup[ch-32][3];
memcpy_P(&bitmap[(x + 5) * 20 + y], &FontLookup[ch - 32][4], 1); //bitmap[(x+5)*20+y] = FontLookup[ch-32][4];
memcpy_P(&bitmap[(x + 6) * 20 + y], &FontLookup[ch - 32][5], 1); //bitmap[(x+6)*20+y] = FontLookup[ch-32][5];
memcpy_P(&bitmap[(x + 7) * 20 + y], &FontLookup[ch - 32][6], 1); //bitmap[(x+7)*20+y] = FontLookup[ch-32][6];
memcpy_P(&bitmap[(x + 8) * 20 + y], &FontLookup[ch - 32][7], 1); //bitmap[(x+8)*20+y] = FontLookup[ch-32][7];
memcpy_Pinv(&bitmap[(x + 1) * 20 + y], &FontLookup[ch - 32][0], 1); //bitmap[(x+1)*20+y] = ~FontLookup[ch-32][0];
memcpy_Pinv(&bitmap[(x + 2) * 20 + y], &FontLookup[ch - 32][1], 1); //bitmap[(x+2)*20+y] = ~FontLookup[ch-32][1];
memcpy_Pinv(&bitmap[(x + 3) * 20 + y], &FontLookup[ch - 32][2], 1); //bitmap[(x+3)*20+y] = ~FontLookup[ch-32][2];
memcpy_Pinv(&bitmap[(x + 4) * 20 + y], &FontLookup[ch - 32][3], 1); //bitmap[(x+4)*20+y] = ~FontLookup[ch-32][3];
memcpy_Pinv(&bitmap[(x + 5) * 20 + y], &FontLookup[ch - 32][4], 1); //bitmap[(x+5)*20+y] = ~FontLookup[ch-32][4];
memcpy_Pinv(&bitmap[(x + 6) * 20 + y], &FontLookup[ch - 32][5], 1); //bitmap[(x+6)*20+y] = ~FontLookup[ch-32][5];
memcpy_Pinv(&bitmap[(x + 7) * 20 + y], &FontLookup[ch - 32][6], 1); //bitmap[(x+7)*20+y] = ~FontLookup[ch-32][6];
memcpy_Pinv(&bitmap[(x + 8) * 20 + y], &FontLookup[ch - 32][7], 1); //bitmap[(x+8)*20+y] = ~FontLookup[ch-32][7];
#endif
void PC1681WE05::LCDWriteString(int row, int pos, unsigned char* arr, int inv) {
unsigned int i = pos;
while((*arr) != '\0') {
// LCDWriteChar(row, i, (*arr), inv);
writeChar(row, i, (*arr), inv);
i++;
arr++;
void PC1681WE05::refresh() {
// Implement refreshing display
void *PC1681WE05::memcpy_Pinv(void * start1, PGM_VOID_P start2, size_t nbytes){
uint8_t *p1 = (uint8_t*)start1;
uint8_t *p2 = (uint8_t*)start2;
unsigned char tmp;
while(nbytes--) {
memcpy_P(&tmp,start2++,1);//*p1++ = (uint8_t)(~*p2++);
tmp=~tmp;
memcpy(start1++,&tmp,1);
and the h file is :
#ifndef PC1681WE05_h
#define PC1681WE05_h
#include <Arduino.h>
#include <avr/io.h>
class PC1681WE05 {
public:
PC1681WE05();
void initLCD();
void lcdOn();
void lcdOff();
void setBacklight(unsigned char light);
void writeBitmap();
void writeBlank();
void writeChar(int x, int y, char ch, bool invert);
void LCDWriteString(int row, int pos, unsigned char* arr, int inv);
void refresh();
private:
void *memcpy_Pinv(void *dest, PGM_VOID_P src, size_t nbytes);
#endif
and the example sketch is :
unsigned char bitmap[160 * 20]; // Define the bitmap array is necessary
PC1681WE05 lcd;
unsigned long lastDisplayTime = 0;
unsigned long displayInterval = 2000; // Display interval in milliseconds
// Initialize LCD
lcd.initLCD();
lcd.lcdOn();
lcd.setBacklight(2); // Set backlight to maximum intensity
// Clear the screen
lcd.writeBlank();
unsigned long currentTime = millis();
if (currentTime - lastDisplayTime >= displayInterval) {
lcd.writeBlank();
lcd.LCDWriteString(0, 0, (unsigned char*)"Hello, World!", 0);
lastDisplayTime = currentTime;
when i compile the code for mega compiled fine , but i doesn't have arduino mega for test the lcd and code ,
can someone here optimizing the library for less ram consumption ,
maybe someone need to know about font_8x8.h is :
const unsigned char FontLookup[][8] PROGMEM = {
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }, // sp
{ 0x04, 0x04, 0x04, 0x04, 0x00, 0x00, 0x04, 0x00 }, // !
{ 0x0A, 0x0A, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x00 }, // "
{ 0x0A, 0x0A, 0x1F, 0x0A, 0x1F, 0x0A, 0x0A, 0x00 }, // #
{ 0x04, 0x0F, 0x14, 0x0E, 0x05, 0x1E, 0x04, 0x00 }, // $
{ 0x18, 0x19, 0x02, 0x04, 0x08, 0x13, 0x03, 0x00 }, // %
{ 0x0C, 0x12, 0x14, 0x08, 0x15, 0x12, 0x0D, 0x00 }, // &
{ 0x0C, 0x04, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00 }, // '
{ 0x02, 0x04, 0x08, 0x08, 0x08, 0x04, 0x02, 0x00 }, // (
{ 0x08, 0x04, 0x02, 0x02, 0x02, 0x04, 0x08, 0x00 }, // )
{ 0x00, 0x04, 0x15, 0x0E, 0x15, 0x04, 0x00, 0x00 }, // *
{ 0x00, 0x04, 0x04, 0x1F, 0x04, 0x04, 0x00, 0x00 }, // +
{ 0x00, 0x00, 0x00, 0x00, 0x0C, 0x04, 0x08, 0x00 }, // ,
{ 0x00, 0x00, 0x00, 0x1F, 0x00, 0x00, 0x00, 0x00 }, // -
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x0C, 0x00 }, // .
{ 0x00, 0x01, 0x02, 0x04, 0x08, 0x10, 0x00, 0x00 }, // /
{ 0x0E, 0x11, 0x13, 0x15, 0x19, 0x11, 0x0E, 0x00 }, // 0
{ 0x04, 0x0C, 0x04, 0x04, 0x04, 0x04, 0x0E, 0x00 }, // 1
{ 0x0E, 0x11, 0x01, 0x02, 0x04, 0x08, 0x1F, 0x00 }, // 2
{ 0x1F, 0x02, 0x04, 0x02, 0x01, 0x11, 0x0E, 0x00 }, // 3
{ 0x02, 0x06, 0x0A, 0x12, 0x1F, 0x02, 0x02, 0x00 }, // 4
{ 0x1F, 0x10, 0x1E, 0x01, 0x01, 0x11, 0x0E, 0x00 }, // 5
{ 0x06, 0x08, 0x10, 0x1E, 0x11, 0x11, 0x0E, 0x00 }, // 6
{ 0x1F, 0x01, 0x02, 0x04, 0x04, 0x04, 0x04, 0x00 }, // 7
{ 0x1E, 0x11, 0x11, 0x0E, 0x11, 0x11, 0x0E, 0x00 }, // 8
{ 0x0E, 0x11, 0x11, 0x0F, 0x01, 0x02, 0x0C, 0x00 }, // 9
{ 0x00, 0x0C, 0x0C, 0x00, 0x0C, 0x0C, 0x00, 0x00 }, // :
{ 0x00, 0x0C, 0x0C, 0x00, 0x0C, 0x04, 0x08, 0x00 }, // ;
{ 0x02, 0x04, 0x08, 0x10, 0x08, 0x04, 0x02, 0x00 }, // <
{ 0x00, 0x00, 0x1F, 0x00, 0x1F, 0x00, 0x00, 0x00 }, // =
{ 0x08, 0x04, 0x02, 0x01, 0x02, 0x04, 0x08, 0x00 }, // >
{ 0x0E, 0x11, 0x01, 0x02, 0x04, 0x00, 0x04, 0x00 }, // ?
{ 0x0E, 0x11, 0x01, 0x0D, 0x15, 0x15, 0x0E, 0x00 }, // @
{ 0x0E, 0x11, 0x11, 0x11, 0x1F, 0x11, 0x11, 0x00 }, // A
{ 0x1E, 0x09, 0x09, 0x0E, 0x09, 0x09, 0x1E, 0x00 }, // B
{ 0x0E, 0x11, 0x10, 0x10, 0x10, 0x11, 0x0E, 0x00 }, // C
{ 0x1E, 0x09, 0x09, 0x09, 0x09, 0x09, 0x1E, 0x00 }, // D
{ 0x1F, 0x10, 0x10, 0x1F, 0x10, 0x10, 0x1F, 0x00 }, // E
{ 0x1F, 0x10, 0x10, 0x1E, 0x10, 0x10, 0x10, 0x00 }, // F
{ 0x0E, 0x11, 0x10, 0x13, 0x11, 0x11, 0x0F, 0x00 }, // G
{ 0x11, 0x11, 0x11, 0x1F, 0x11, 0x11, 0x11, 0x00 }, // H
{ 0x0E, 0x04, 0x04, 0x04, 0x04, 0x04, 0x0E, 0x00 }, // I
{ 0x07, 0x02, 0x02, 0x02, 0x02, 0x12, 0x0C, 0x00 }, // J
{ 0x11, 0x12, 0x14, 0x18, 0x14, 0x12, 0x11, 0x00 }, // K
{ 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x1F, 0x00 }, // L
{ 0x11, 0x1B, 0x15, 0x15, 0x11, 0x11, 0x11, 0x00 }, // M
{ 0x11, 0x19, 0x19, 0x15, 0x13, 0x13, 0x11, 0x00 }, // N
{ 0x0E, 0x11, 0x11, 0x11, 0x11, 0x11, 0x0E, 0x00 }, // O
{ 0x1E, 0x11, 0x11, 0x1E, 0x10, 0x10, 0x10, 0x00 }, // P
{ 0x0E, 0x11, 0x11, 0x11, 0x15, 0x12, 0x1D, 0x00 }, // Q
{ 0x1E, 0x11, 0x11, 0x1E, 0x14, 0x12, 0x11, 0x00 }, // R
{ 0x0E, 0x11, 0x10, 0x0E, 0x01, 0x11, 0x0E, 0x00 }, // S
{ 0x1F, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0x00 }, // T
{ 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x0E, 0x00 }, // U
{ 0x11, 0x11, 0x11, 0x11, 0x11, 0x0A, 0x04, 0x00 }, // V
{ 0x11, 0x11, 0x11, 0x15, 0x15, 0x1B, 0x11, 0x00 }, // W
{ 0x11, 0x11, 0x0A, 0x04, 0x0A, 0x11, 0x11, 0x00 }, // X
{ 0x11, 0x11, 0x11, 0x0A, 0x04, 0x04, 0x04, 0x00 }, // Y
{ 0x1F, 0x01, 0x02, 0x04, 0x08, 0x10, 0x1F, 0x00 }, // Z
{ 0x0E, 0x08, 0x08, 0x08, 0x08, 0x08, 0x0E, 0x00 }, // [
{ 0x00, 0x10, 0x08, 0x04, 0x02, 0x01, 0x00, 0x00 }, // /
{ 0x0E, 0x02, 0x02, 0x02, 0x02, 0x02, 0x0E, 0x00 }, // ]
{ 0x04, 0x0A, 0x11, 0x00, 0x00, 0x00, 0x00, 0x00 }, // ^
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00 }, // _
{ 0x10, 0x08, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00 }, // `
{ 0x00, 0x00, 0x0E, 0x01, 0x0F, 0x11, 0x0F, 0x00 }, // a
{ 0x10, 0x10, 0x16, 0x19, 0x11, 0x11, 0x1E, 0x00 }, // b
{ // c
0x00,
0x00,
0x0E,
0x11,
0x10,
0x11,
0x0E,
0x00 },
{ // d
0x01,
0x01,
0x0D,
0x13,
0x11,
0x11,
0x0F,
0x00 },
{ // e
0x00,
0x00,
0x0E,
0x11,
0x1F,
0x10,
0x0E,
0x00 },
{ // f
0x02,
0x05,
0x04,
0x0E,
0x04,
0x04,
0x04,
0x00 },
{ // g
0x00,
0x0D,
0x13,
0x13,
0x0D,
0x01,
0x0E,
0x00 },
{ // h
0x10,
0x10,
0x16,
0x19,
0x11,
0x11,
0x11,
0x00 },
{ // i
0x04,
0x00,
0x0C,
0x04,
0x04,
0x04,
0x0E,
0x00 },
{ // j
0x02,
0x00,
0x06,
0x02,
0x02,
0x12,
0x0C,
0x00 },
{ // k
0x08,
0x08,
0x09,
0x0A,
0x0C,
0x0A,
0x09,
0x00 },
{ // l
0x0C,
0x04,
0x04,
0x04,
0x04,
0x04,
0x0E,
0x00 },
{ // m
0x00,
0x00,
0x1A,
0x15,
0x15,
0x15,
0x15,
0x00 },
{ // n
0x00,
0x00,
0x16,
0x19,
0x11,
0x11,
0x11,
0x00 },
{ // o
0x00,
0x00,
0x0E,
0x11,
0x11,
0x11,
0x0E,
0x00 },
{ // p
0x00,
0x16,
0x19,
0x19,
0x16,
0x10,
0x10,
0x00 },
{ // q
0x00,
0x0D,
0x13,
0x13,
0x0D,
0x01,
0x01,
0x00 },
{ // r
0x00,
0x00,
0x16,
0x19,
0x10,
0x10,
0x10,
0x00 },
{ // s
0x00,
0x00,
0x0F,
0x10,
0x1E,
0x01,
0x1F,
0x00 },
{ // t
0x08,
0x08,
0x1C,
0x08,
0x08,
0x09,
0x06,
0x00 },
{ // u
0x00,
0x00,
0x12,
0x12,
0x12,
0x12,
0x0D,
0x00 },
{ // v
0x00,
0x00,
0x11,
0x11,
0x11,
0x0A,
0x04,
0x00 },
{ // w
0x00,
0x00,
0x11,
0x11,
0x15,
0x15,
0x0A,
0x00 },
{ // x
0x00,
0x00,
0x11,
0x0A,
0x04,
0x0A,
0x11,
0x00 },
{ // y
0x00,
0x00,
0x11,
0x11,
0x13,
0x0D,
0x01,
0x0E },
{ // z
0x00,
0x00,
0x1F,
0x02,
0x04,
0x08,
0x1F,
0x00 },
0x02,
0x04,
0x04,
0x08,
0x04,
0x04,
0x02,
0x00 },
0x04,
0x04,
0x04,
0x00,
0x04,
0x04,
0x04,
0x00 },
0x08,
0x04,
0x04,
0x02,
0x04,
0x04,
0x08,
0x00 },
0x08,
0x15,
0x02,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 5F
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 60
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 61
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 62
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 63
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 64
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 65
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 66
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 67
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 68
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 69
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 6A
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 6B
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 6C
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 6D
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 6E
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 6F
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 70
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 71
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 72
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 73
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 74
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 75
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 76
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 77
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 78
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 79
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 7A
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 7B
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 7C
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 7D
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 7E
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 },
{ // 7F
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00,
0x00 }
