Lego NXT LCD connections: What do they mean?
What do the connections mean in picture 1?
Vcc is positive power.
SDA - the I2C data line
SCK - the I2C clock line
CD - ?? - could be chip disable but I doubt it.
RST (Bar) - Active low reset line
CS0 - Chip select zero
CD = Data/Command select //I think?
also what should I do to find the correct signals for each pin?
Pin = Note // Signal
Vcc = 3.3V // Positive Power
SDA = ___ // ?????????
SCK = SqWav// any specific Rate???
CD = ___ // ????????
RST = HIGH // Connected to Vcc (3.3V)
CS0 = ___ // ????????
The UC1610 controller requires very similar external components.
Compare the schematic here: GitHub - olikraus/dogm128: Automatically exported from code.google.com/p/dogm128
In order to do what?
It is an I2C device running off 3v3, what do you want to connect it to?
