# Lego powerfunctions IR
**URL:** <https://forum.arduino.cc/t/lego-powerfunctions-ir/38238>\
**Category:** Development\
**Created:** [November 26, 2008, 10:23pm UTC](https://forum.arduino.cc/t/lego-powerfunctions-ir/38238 "2008-11-26T22:23:39Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Post date:** [November 26, 2008, 10:23pm UTC](https://forum.arduino.cc/t/lego-powerfunctions-ir/38238/1 "2008-11-26T22:23:39Z")
</div>
Ive had a idea to use a irduino as a IR transmitter to control the lego powerfunction receiver.
But I am a total nooby in this, ive done some research and found the protocol document for the lego transmitter:
> **[LEGO\_Power\_Functions\_RC.pdf](https://www.philohome.com/pf/LEGO_Power_Functions_RC.pdf)**
> 398.32 KB
And here is some example code of someone who made his lego RCX brick to do what i want with the arduino:
[http://www.fial.com/bob/lego/PowerFunctions.zip](http://www.fial.com/bob/lego/PowerFunctions.zip)
You can do more things then the lego transmitter, like PWM!
Can someone help me out, or put me one the right track so i can make it?
**Post date:** [November 27, 2008, 10:01pm UTC](https://forum.arduino.cc/t/lego-powerfunctions-ir/38238/2 "2008-11-27T22:01:24Z")
</div>
Ive made some starting code, but its not working.
I used most of the code from the RCX brick because its also C code
```cpp
//mode
#define COMBO_DIRECT_MODE 0x01
#define SINGLE_PIN_CONTINUOUS 0x2
#define SINGLE_PIN_TIMEOUT 0x3
#define SINGLE_OUTPUT 0x4
//PWM speed steps
#define PWM_FLT 0x0
#define PWM_FWD1 0x1
#define PWM_FWD2 0x2
#define PWM_FWD3 0x3
#define PWM_FWD4 0x4
#define PWM_FWD5 0x5
#define PWM_FWD6 0x6
#define PWM_FWD7 0x7
#define PWM_BRK 0x8
#define PWM_REV7 0x9
#define PWM_REV6 0xA
#define PWM_REV5 0xB
#define PWM_REV4 0xC
#define PWM_REV3 0xD
#define PWM_REV2 0xE
#define PWM_REV1 0xf
//channel
#define CH1 0x0
#define CH2 0x1
#define CH3 0x2
#define CH4 0x3
//output
#define RED 0x0
#define BLUE 0x1
int IRPin = 13;
int toggle[4] = {0,0,0,0};
  pinMode(IRPin, OUTPUT);
  //Serial.begin(9600);
  //delay(2);
  SingleOutput(PWM_FWD7, RED, CH1);
  //delay(2000);
void pf_send(int code1, int code2)
  int x = 128;
  start_stop_bit();
  while (x)
    digitalWrite(IRPin, HIGH);
    tx_pause();
    digitalWrite(IRPin, LOW);
    if (code1 & x) //high bit
      high_pause();
    else //low bit
      low_pause();
    x >>= 1;  //next bit
  x = 128;
  while (x)
    tx_pause();
    if (code2 & x) // high bit
      high_pause();
    else //low bit
      low_pause();
    x >>= 1;  //next bit
  delay(10);
void SingleOutput(int pwm, int output, int channel)
   int nib1, nib2, nib3, nib4, i;
   //set nibs
   nib1 = toggle[channel] | channel;
   nib2 = SINGLE_OUTPUT | output;
   nib3 = pwm;
   nib4 = 0xf ^ nib1 ^ nib2 ^ nib3;
   for(i = 0; i < 6; i++)
     message_pause(channel, i);
     pf_send(nib1 << 4 | nib2, nib3 << 4 | nib4);
   if(toggle[channel] == 0)
     toggle[channel] = 8;
     toggle[channel] = 0;
void start_pause()
  delayMicroseconds(1014);
void high_pause()
  delayMicroseconds(546);
void low_pause()
  delayMicroseconds(260);
void tx_pause()
  delayMicroseconds(156);
void message_pause(int channel, int count)
  unsigned char a = 0;
  if(count == 0)
    a = 4 - channel + 1;
  else if(count == 1 || count == 2)
    a = 5;
  else if(count == 3 || count == 4)
    a = 5 + (channel + 1) * 2;
  delayMicroseconds(a * 77);
void start_stop_bit()
 tx_pause();
 start_pause();
The RCX code used some sort of for loop delay, i use delayMicroseconds.
Can this be the problem?
Can someone help me?
**Post date:** [November 28, 2008, 5:13pm UTC](https://forum.arduino.cc/t/lego-powerfunctions-ir/38238/3 "2008-11-28T17:13:01Z")
</div>
Oke Ive got it working now!!!
IR need to pulse ofcourse, so i used David Cuartielles code of the remote control the oscillationWrite() function to make a pulse.
Now it works like a charm, the code is not done yet, but if you put this on your arduino with a ir led on port 13 your lego 8275 bulldozer wil drive forward on a interval of 2 secs
Not bad for me _couch_ first time i play with arduino.
```cpp
//mode
//PWM speed steps
#define PWM_FLT 0x0
#define PWM_BRK 0x8
//speed
#define RED_FLT 0x0
#define RED_FWD 0x1
#define RED_REV 0x2
#define RED_BRK 0x3
#define BLUE_FLT 0x0
#define BLUE_FWD 0x4
#define BLUE_REV 0x8
#define BLUE_BRK 0xC
//channel
#define CH1 0x0
#define CH2 0x1
#define CH3 0x2
#define CH4 0x3
//output
#define RED 0x0
#define BLUE 0x1
int IRPin = 13;
  //delay(2);
  ComboMode(BLUE_REV, RED_FWD, CH1);
  delay(2000);
  int x = 128;
  start_stop_bit();
  while (x)
    oscillationWrite(IRPin, 156);
      high_pause();
    else //low bit
      low_pause();
    x >>= 1;  //next bit
  x = 128;
  while (x)
      high_pause();
    else //low bit
      low_pause();
    x >>= 1;  //next bit
  start_stop_bit();
  delay(10);
void ComboMode(int blue_speed, int red_speed, int channel)
  //set nibs
  nib1 = channel;
  nib2 = COMBO_DIRECT_MODE;
  nib3 = blue_speed | red_speed;
   //set nibs
   nib3 = pwm;
void start_pause()
void high_pause()
void low_pause()
void tx_pause()
  if(count == 0)
    a = 5;
  //digitalWrite(IRPin, HIGH);
  //tx_pause();
  //digitalWrite(IRPin, LOW);
  start_pause();
void oscillationWrite(int pin, int time) {
  for(int i = 0; i <= time/26; i++) {
    digitalWrite(pin, HIGH);
    delayMicroseconds(13);
    digitalWrite(pin, LOW);
**Post date:** [November 28, 2008, 10:57pm UTC](https://forum.arduino.cc/t/lego-powerfunctions-ir/38238/4 "2008-11-28T22:57:33Z")
</div>
Oke, ive got the code fully working now, and i made a java program to control it.
Power is ofcourse to switch it on (maybe wait a few sec till the arduino is done booting)
channel selector;
2 throttle sliders, and you can link them;
checkbox below is to turn Forward\<-\> backwards
arduino code: [http://www.rjw.speedxs.nl/arduino/lego\_ir.pde](http://www.rjw.speedxs.nl/arduino/lego_ir.pde)
java program: [http://www.rjw.speedxs.nl/arduino/Lego](http://www.rjw.speedxs.nl/arduino/Lego) Powerfunctions.rar atmthe Java program is hardcoded to COM4.
**Author:** ![vanakaru](https://avatars.discourse-cdn.com/v4/letter/v/bbe5ce/32.png) [@vanakaru](https://forum.arduino.cc/u/vanakaru)\
**Post date:** [October 24, 2010, 5:17pm UTC](https://forum.arduino.cc/t/lego-powerfunctions-ir/38238/5 "2010-10-24T17:17:27Z")
</div>
I would like to try this code of yours. Could you fix the dead links or email me at erikik at hot dot ee
**Post date:** [January 21, 2011, 1:25pm UTC](https://forum.arduino.cc/t/lego-powerfunctions-ir/38238/6 "2011-01-21T13:25:46Z")
</div>
Yes, please share the code!
**Post date:** [May 6, 2021, 7:54pm UTC](https://forum.arduino.cc/t/lego-powerfunctions-ir/38238/7 "2021-05-06T19:54:56Z")
</div>
