Hello all,
I'm currently working on a new project to measure the distance of a film tape supplied in a roll.
The main goal is to be able to measure the tape lenght of the roll, to check if it matches the purchased value, for example 50 meters.
I believe that an Arduino, an LCD and an encoder should be enough, but i've some doubts regarding the correct encoder.
The encoder must read in both ways because the tape may be pushed back, which means that in one direction it will count up, and on the opposite direction it will decrease the current value.
Can you please advise if is possible to create this project?
Is there any similar projects available?
cruzjos:
Yes, very similar things have been done many times. Do a forum search for 'wire cutter'. Add 'arduino' and there are also a number of YT videos along the same line.
