Setting up a home automation system using Arduinos and have been wondering how long sensor wires should be as a maximum.
I'm planning to run the typical sensors off a number of arduino nodes reporting back to OpenHAB via MQTT (either via Ethernet - if I can find a reliable shield, or using nrf24 transceivers).
At the Arduino node, how long should the sensor cables sensibly be before they either become unreliable or introduce too much loss/resistance?
I'm looking at DHT22, barometric pressure, reed switches, PIR, smoke sensors, the usual...
Also, what kind of wire should I use? I have just wired the house up with CAT6 and have a box of that downstairs - does it make sense to use that for sensors, or would I be better off with something else?
