Leonardo as Programmer
Hi my Arduino Leonardo works great. but i can not use it as Programmer. I can install the Arduino ISP sketch on it. when i write an bootloader to an ATmega328P commes this mesage
Arduino: 1.6.3 (Windows 7), Platine: "Arduino Nano, ATmega328"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM7 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
avrdude: Version 6.0.1, compiled on Mar 30 2015 at 14:56:06
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM7
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
Probleme beim Hochladen auf die Platine. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload .
avrdude done.  Thank you.
I don't know if it makes a difference but I see that ArduinoISP sketch does not include:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
I'd try adding that.
Also note that the ICSP header is the only way to connect to the SPI pins on an Arduino Leonardo. You don't use pins 11, 12, and 13 like on an Arduino UNO.
I have found an article that means ist an windows problem.
http://www.correderajorge.es/the-powerful-attiny-arduino/
also i make the same on Ubuntu an the result is
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
i have no idea who i can install the bootloader with the option -F
the target is an ATmega328P
