He everyone!
I started experimenting with an Uno (which worked fine) and now want to move to a Leonardo. But whatever I do, when uploading to the (brand new) Leonardo it tells me:
avrdude: butterfly_recv(): programmer is not responding
what i've tried so far:
- on osx -> "about this mac" -> "system report" -> checked that the arduino shows up as usb device.
- in the ide -> set the board to "Arduino Leonardo"
- in the ide -> set the port to "/dev/cu.usbmodem14201 (Arduino Leonardo)"
- in the ide -> get bpard info shows
BN: Arduino Leonardo
VID: 0x2341
PID: 0x8036
SN: Upload any sketch to obtain it
switched usb cables
switched usb ports
switched computers
the full output from the compiler is this:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/private/var/folders/n5/hf0hshx506ddv9c9kbdxkxr00000gn/T/AppTranslocation/4D24FEA3-B178-44A3-A419-2981D90DF31C/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/wouter/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem14201
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = "�ߍ��"; type =
Software Version = .; Hardware Version = .
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
avrdude done. Thank you.
the selected serial port
does not exist or your board is not connected
I've been googling a lot and seen various people mention that holding or pressing the reset button during upload should fix this, but unfortunately that doesn't do the trick for me.
Anyone got any idea what could be wrong?
Thanks!!!!
Wouter
