Leonardo bootloader broken when code is uploaded
I am toying with direct ISR and port manipulation because I need faster interrupt response. The code below breaks my leonardo but works on an uno. When I upload the code windows stops recognizing the leonardo with the error "Device Descriptor failed". If I push reset and reload a stock example code it will start working again. So I know its the bootloader. Any ideas?
ISR (INT2_vect) //pin 0
  Serial.println("Test");
void setup ()
 DDRD = DDRD | B00000000;
 EICRA &= ~(bit(ISC00) | bit (ISC01));  // clear existing flags
 EICRA |= bit (ISC01);    // set wanted flags (falling level interrupt)
 EIMSK |= bit (INT2);     // enable it
}  // end of setup
void loop () { }
I wonder if calling Serial.println in the interrupt service routine might be causing problems.
Well, it's not exactly a bootloader. The USB code on the Leonardo doesn't run on a separate processor like the UNO. It's all on the one processor with your code.
If your code locks up in a bad way, then the USB also stops working.
I have tried it without the serial.println, that did not help.
I narrowed down to using INT2(pin 0). Is there more to using that interrupt since its the RX pin?
ISC00 and ISC01 are used to configured External Interrupt 0 not 2.
Bitwise-or with zero has no side-effects.
I am unsure what you mean by that.
If the right-side of the bitwise-or is zero then the result of the bitwise-or is...
