Leonardo Can Bus not recieving data
Hello
I am trying to read my vehicoes CanB with the Leonardo Can Bus Shield Leonardo CAN BUS board.
I have it configured via the 4 pin inputs not the DB9 conector. I have checked the vehices OBD port to confirm the correct readings at CanH and CanL and can see on the meter there is activity on the pins. I have checked at the CanH and CanL inputs on the board when plugged into OBD and im getting signal to the board.
When I try to send data I get message send confirmation however there is no data being read by the board.
I have tried many different librarys and edited my code to suit each but to no avail. I just cant get it to read data.
I have searched here but all similar topics are around code not compiling, my issue is getting it to read data once running.
Can anyone help please?
Excuse the code its a bit messy atm as its been edited 50 times for different librarys, but I can tell why its not working.
#include <Arduino.h>
#include <mcp_can.h>
#include <SPI.h>
#define CANint 2
unsigned char len = 0;
unsigned char buf[8];
unsigned long ID = 0;
unsigned long line = 0;
unsigned long time;
byte data[8] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07};
MCP_CAN CAN0(17); // Set CS to pin 17
  while (!Serial) {
    Serial.print("I will wait here forever...");
  pinMode(23, OUTPUT);
  digitalWrite(23, HIGH);
  pinMode(CANint, INPUT);
  Serial.println("CAN init:");
  if (CAN0.begin(CAN_500KBPS) == CAN_OK) {
    Serial.println("Can Init Success");
    Serial.println("Can Init Failed");
    while (1) {
  Serial.println("Good to go!");
  time = millis();
  if (CAN_MSGAVAIL == CAN0.checkReceive() && line < 10000) {         // Check to see whether data is read
    digitalWrite(23, LOW);
    if (CAN0.readMsgBuf(&len, buf)) {   // Read data
      ID = CAN0.getCanId();
      line = line + 1;
      Serial.print("ID:");
      Serial.print(ID, HEX); // Output HEX Header
      Serial.print("\t");
      Serial.print("Len:");
      Serial.print(len);
      Serial.print("\t");
      Serial.print("DATA:");
      for (int i = 0; i < len; i++) { // Output 8 Bytes of data in Dec
        Serial.print(buf[i]);
        Serial.print("\t");
      Serial.print("\t");
      Serial.print("time:");
      Serial.print(time); // Timestamp
      Serial.print("\t");
      Serial.print("line:");
      Serial.println(line); // Line Number
    // send data:  ID = 0x100, Standard CAN Frame, Data length = 8 bytes, 'data' = array of data bytes to send
    byte sndStat = CAN0.sendMsgBuf(0x100, 0, 8, data);
    if (sndStat == CAN_OK) {
      Serial.println("Message Sent Successfully!");
      Serial.println("Error Sending Message...");
    delay(100);   // send data per 100ms
  delay(10);
What's that for?
"Pin 23", on a Leonardo?
All good, I found my issue, it was hardware related.
pin 23 is and LED
13 != 23
