leonardo cannot berecognized after uploading
Hi folks,
would like to share with you. I use my recent bought Leonardo, uploaded software on it, afterward, I found I can't upload anymore again. that's weird, due to the system still recognized by IDE,
My solution is using the older IDE 1.6.0 version, program the blink again, I found this works and it can be wake up the board again. The new IDE programming working good again. I nearly throw away all malfunction Leonardo. haha.
** time being, I am trying to use Leonardo as a Keyboard simulator, I thought this might be related to this issue from the beginning, but finally, I found this is not!
Any people who have the same please report, Maybe my case not unique. this can help the Arduino team follow up.
It is not really a fault in the IDE as such but the way the LEO works with such keyboard / mice emulator sketches.
Normally you would press RESET during the upload to force it into the mode you need to re-upload sketches.
Restarting the 'normal' IDE might do the trick as well.
It has happened to me that the Leo does not want to upload; this was not related to HID functionality. In most cases the COM port had changed. Picking the correct COM port solved the issue; if that did not solve the issue, reset did.
