Looking at the Leonardo info, it seems it doesn't use digital pins 0 and 1 anymore, at least not by default. I just wanted to double check - can I now use these pins for my sketches?
Yes, you can use those pins as General Purpose I/O.
They still have a hardware Serial UART attached to them, but it is not used for PC communication. This also means if you want to interface with a serial device, like a GPS receiver, it is much easier with the Leo since that hardware UART is now available.
Thanks. I know nothing about serial interface, but I do have a project that uses an xbee. I wonder if there is any advantage of using pins 0 and 1 with the xbee. If so, I'm assuming a library would have to be written to take advantage of the UART.
You don't need to use or create an additional library. The Leonardo's hardware UART is referenced as Serial1 (as opposed to Serial which is used for PC communications.)
Cheers!
