Leonardo Eth not compatible to Uno with EthernetShield?
Hi all,
this is my first question I post in this forums, so please be patient with me. I already searched the forums for 2 hours , reading posts but I was not able to find a solution to my problem.
I am facing problems with the LeonardoETH which do not appear when using a Arduino Uno with a EthernetShield. Is there a main difference between this two devices?
I have already successfully buildt an NFC keypad based on the MFRC522 library by miguelbalboa (GitHub - miguelbalboa/rfid: Arduino RFID Library for MFRC522) and the keypad library. This is buildt on an arduino Uno with stacked EthernetBoard (Wiznet 5100 Chip) and a Kyypad Matrix (3x4 buttons) and the RFID-Breakout (http://www.amazon.de/SunFounder-Mifare-Antenna-Proximity-Arduino/dp/B00E0ODLWQ)
Basically the solution does the following: If a NFC Card is detected, it stores the ID of the card and waits for a pin code. After entering the pincode it sends this two informations (nfc ID and pincode) via a http POST to a webserver (via ethernet client library).
This ALL WORKS FINE if I use the Arduino Uno with the Ethernet Shield.
So I tried to make the hardware smarter (and even smaller), I ordered an arduino leonardo ETH with integrated Ethernet-Interface ... and connected everything like before on the Uno, loaded my sketch - but that didnt work. Everything seems to work - EXCEPT THE NFC functionality.
I tried a lot of things, like using the 6 pin ICSP Header for MOSI,MISO,SCK of the RF522 instead of the 11,12,13 GPIOs
I also tried to manually set the CS to low/high in setup to ensure there is no conflict with the CS of the Ethernet Chip (Wiznet 5500?) and the SD-Card which both also seem to use ICSP ...
Has anybody have similar problems with LeonardoETH and ICSP Communication to external devices?
Any help is highly appreciated
Thanks in advance
Don
Where is your code?
Thanks for the answer.
This is the code that works on the UNO R3 with he Ethernet-Shield.
If I use this code on the Uno/EthernetShield combination it shows the correct Version v.2 for the NFC-Reader
Using this code on the Leonardo ETH doesnt detect the Reader (// When 0x00 or 0xFF is returned, communication probably failed) in the "ShowReaderDetails"
regards
Don
THis is the sketch I am using right now
// KEYPAD --------------
#include <Keypad.h>
// SPI & RFID ----------
#include <SPI.h>
#include <MFRC522.h>
// ETHERNET, WEB & API -
#include <Ethernet.h>
// WEBADMIN PAGE -------
#include <RestClient.h>
// ########## KEYPAD Defs ##########
const byte ROWS = 4;
const byte COLS = 3;
//Keymap
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = { 3, 2, A5, 0 };
byte colPins[COLS] = { 7, 6, 5 };
// KEYPAD CREATE ---------
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
// ########## NFC Defs ##########
#define SS_PIN 8
#define RST_PIN 9
// NFC CREATE -------------
MFRC522 mfrc522(SS_PIN, RST_PIN);
// ########## WEB SERVER DEFS ##########
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1,102);
IPAddress gateway(192,168,1,1);
IPAddress subnet(255,255,255,0);
unsigned int port = 80;
EthernetServer server(port);
EthernetClient client;
// ########## WEB API DEFS #########
char apiServer[15+1] = "192.168.1.10";
char apiPath[50+1] = "/keypad";
RestClient restAPI = RestClient(apiServer);
// ########## GLOBAL VARS ##########
unsigned int status; // 0 = idle, 1 = card scanned
char uid[20+1]; // 2char for each byte - 4, 7 and 10 Byte cards possible with 20 chars
char pin[20+1]; // 19 keypresses max!!! 1 char reserve to prevent overflow
// ########## LEDs and Buzzer ##########
const int led1 = A1; //red
const int led2 = A2; //yellow
const int led3 = A3; //green
const int led4 = A4; //blue
const int buzzer = A0;
// ########## TIMEOUT FOR USAGE ##########
unsigned long currentMillis;
unsigned long lastUsageMillis = 0;
unsigned int usageTimeOut = 4000;
// setup
// Open serial
// KEYPAD INIT ----------
// LED AND BUZZER INIT
pinMode(led1,OUTPUT);
pinMode(led2,OUTPUT);
pinMode(led3,OUTPUT);
pinMode(led4,OUTPUT);
pinMode(buzzer,OUTPUT);
// CS-Lines for SD and Ethernet
pinMode(4, OUTPUT);
pinMode(10, OUTPUT);
// RFID READER INIT -----
SPI.begin();
mfrc522.PCD_Init(); // Init RC522
Serial.print(F("NFC:"));
ShowReaderDetails(); // Show RC522 Card Reader details
// ETHERNET,API & WEB config & other parameters
delay(1000); // !!! Wait before init of ethernet to not conflict with NFC init
Ethernet.begin(mac, ip, gateway, gateway, subnet);
server.begin();
Serial.print(F("IP is:"));
Serial.println(Ethernet.localIP());
Serial.println("READY...");
// main loop
currentMillis = millis();
if(currentMillis - lastUsageMillis > usageTimeOut && status == 1){
// no input or card for more than x seconds (x=usageTimeout)
buzz(1,900);
setBack();
key();
nfc();
delay(1);
// set card uid and pin to zero
void setBack(){
uid[0] = 0;
pin[0] = 0;
status = 0;
buzz(0,0);
led('r', 0, 0, 0, 0);
led('y', 0, 0, 0, 0);
led('g', 0, 0, 0, 0);
led('b', 0, 0, 0, 0);
//freeRam ();
// check for pin code
void key (){
if(status == 1){ // 1 = a card was already scanned
char key = kpd.getKey();
if(key)
// Serial.println(key);
// prevent timeout
lastUsageMillis = currentMillis;
led('g', 2, 1, 300, 1);
int len = strlen(pin);
pin[len]=key;
pin[len+1]=0;
if(pin[0] == '*'){ //log out request
led('g', 1, 0, 0, 0);
sendRequest();
if(strlen(pin) == 4 && pin[0] != '#'){
sendRequest();
else if(key == '#' && strlen(pin) > 2 && pin[0] == '#'){ //admin command mode
sendRequest();
else if(strlen(pin) > 19){
// prevent overflowing pin array
led('g',0,0,0,0);
led('y',0,0,0,0);
led('r',1,0,0,0);
buzz(1,900);
// set back uid and pin to idle mode and unlight led(s)
setBack();
// check for nfc card
void nfc(){
// Look for new cards dont work
if (mfrc522.PICC_IsNewCardPresent() && mfrc522.PICC_ReadCardSerial()) {
// Show some details of the scanned card
if (mfrc522.uid.size != strlen(uid)/2){
// normally uid = \0 in idle mode so if uid is present ... its new
// prevent timeout
unsigned int i;
for (i = 0; i < mfrc522.uid.size; i++)
char buf[3];
// make hex strings from uidBytes
sprintf(buf, "%02x", mfrc522.uid.uidByte*); // hex 2 digit formatting with leading 0 of Bytes*
// each hex value has 2 "digits" now
_ uid[i*2] = buf[0]; // i=0 -> uid[0], i= 1 -> uid[2]_
_ uid[(i2)+1] = buf[1]; // i=0 -> uid[1], i= 1 -> uid[3]_
_uid[mfrc522.uid.size
2] = 0;_
Serial.println(uid);
  • buzz(1,300);*
  • led('y',1,0,0,0);*
  • status = 1;*
  • // Card Type*
  • Serial.print(F("card type: "));*
  • byte piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);*
  • Serial.println(mfrc522.PICC_GetTypeName(piccType));*
    // led functions for visual response/feedback
    void led(char color, unsigned int val, unsigned int times, unsigned int msec, unsigned int buzzerOn){
    // led = 1-4 (1=red, 2=yellow, 3=green, 4=blue )
    unsigned int pin;
    switch (color) {
    case 'r':
    pin = led1;
    case 'y':
    pin = led2;
    case 'g':
    pin = led3;
    default:
  • pin = led4;*
    // val = 0-2 (0 = off, 1 = on, 2 = pattern)
    unsigned int interval = msec/times/2;
    unsigned int i;
    switch (val) {
    case 1:
    digitalWrite(pin,HIGH);
    case 2:
    for (i = 0; i < times; i++)
  • digitalWrite(pin,HIGH);*
  • if(buzzerOn == 1){*
  • digitalWrite(buzzer,HIGH);*
  • delay(interval);*
  • digitalWrite(pin,LOW);*
  • digitalWrite(buzzer,LOW);*
  • if(times > 1){*
  • delay(interval);*
    default:
    // buzzer function for acoustic response/feedback
    void buzz(unsigned int times, unsigned int msec){
    if(times == 0){
    else{
    unsigned int i;
  • delay(interval);*
  • if(times > 1){*
  • delay(interval);*
    // get details about RC522 hardware
    void ShowReaderDetails() {
    // Get MFRC522 software version
    byte v = mfrc522.PCD_ReadRegister(mfrc522.VersionReg);
    Serial.print(F("0x"));
    Serial.print(v, HEX);
    if (v == 0x91)
    Serial.print(F("=v1.0"));
    else if (v == 0x92)
    Serial.print(F("=v2.0"));
    Serial.print(F("=v?.?"));
    Serial.println("");
    if ((v == 0x00) || (v == 0xFF)) {
    Serial.println(F("NFC ERROR"));
    // send HTTP POST request to REST-API server
    void sendRequest(){
    char reqParm[150];
    reqParm[0]=0;
    strcat(reqParm,"{'n':'");
    strcat(reqParm,uid);
    strcat(reqParm,"','p':'");
    strcat(reqParm,pin);
    strcat(reqParm,"'}");
    Serial.println(F("Reqest:"));
    Serial.println(reqParm);
    String response = "";
  • int statusCode = restAPI.post(apiPath, reqParm, &response);*
Serial.print(F("Status:"));
Serial.println(statusCode);
Serial.print(F("Response:"));
Serial.println(response);
if(statusCode == 200){
int len = response.length();
//response[length-1] = '\0';
int delimiter = response.lastIndexOf(':');
String commandName = response.substring(1,delimiter);
String commandValue = response.substring(delimiter+1, len-1);
// split response in command, and value ...
Serial.println("c=" + String(commandName) + " v=" + String(commandValue));
if(commandName == "led"){
char color = commandParameter1.charAt(0);
int type = commandParameter2.toInt();
int times = commandParameter3.toInt();
int interval = commandParameter4.toInt();
int buzzerOn = commandParameter5.toInt();
//char val[20] = commandValue.toChar();
led(color,type,times,interval,buzzerOn);
else if(commandName == "buzzer"){
buzz(times,interval);
else{
  • Serial.println(F("invalid response"));*
  • led('r',2,1,900,1);*
  • led('r',1,0,0,0);*
  • delay(1500);*
    setBack();
    else{
    Serial.println(F("Request failed!"));
    led('g',0,0,0,0);
    led('y',0,0,0,0);
    buzz(1,900);
    led('r',1,0,0,0);
    delay(1500);
    setBack();
The Leonardo does not have the SPI data pins on any digital pins. They are only on the ICSP pins. Maybe that is your problem?
Thanks SurferTim, for your suggestion,
as I wrote in my initial post:
I have already changed the connection from the GPIO/shared pins of the Uno to the dedicated ICSP-6-pin-header of the leonardo
is there anything else i have to do ?
thanks and regards
Don
