I have a leonardo and need to get it working with my fedora 17.
In windows7 uploading worked out good. now its good blink on.
When i tried to install on fedora (through both, yum and the binary download from here) everything is fine, it has serial connection. also serial read is working for the normal user, but it doesnt send code to the arduino.
the error i get is the same each time:
processing.app.debug.RunnerException: Couldn’t find a Leonardo on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board's reset button after initiating the upload.
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:150)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
at processing.app.Sketch.upload(Sketch.java:1706)
at processing.app.Sketch.exportApplet(Sketch.java:1662)
at processing.app.Sketch.exportApplet(Sketch.java:1634)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2346)
at java.lang.Thread.run(Thread.java:722)
although i can see it in /dev/ttyAC* and it does communicate (rx/tx leds)
[ 2469.910077] usb 6-1: new full-speed USB device number 42 using uhci_hcd
[ 2470.079142] usb 6-1: New USB device found, idVendor=2341, idProduct=0036
[ 2470.079147] usb 6-1: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 2470.079150] usb 6-1: Product: Arduino Leonardo
[ 2470.079152] usb 6-1: Manufacturer: Arduino LLC
[ 2470.081225] cdc_acm 6-1:1.0: ttyACM0: USB ACM device
[ 2477.704099] usb 6-1: USB disconnect, device number 42
[ 2477.912084] usb 6-1: new full-speed USB device number 43 using uhci_hcd
[ 2478.072140] usb 6-1: New USB device found, idVendor=2341, idProduct=8036
[ 2478.072144] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2478.072147] usb 6-1: Product: Arduino Leonardo
[ 2478.072150] usb 6-1: Manufacturer: Arduino LLC
[ 2478.074215] cdc_acm 6-1:1.0: This device cannot do calls on its own. It is not a modem.
[ 2478.074241] cdc_acm 6-1:1.0: ttyACM0: USB ACM device
[ 2478.081215] input: Arduino LLC Arduino Leonardo as /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.2/input/input29
[ 2478.081687] hid-generic 0003:2341:8036.0014: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Leonardo] on usb-0000:00:1d.0-1/input2
when i list /dev/yttA* it is listed, it does reset from arduino ide and dissapears for short, but it is not uploading the sketch..
im getting the same message all the time, but i do have selected the right port, right board,...:
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2373)
