Leonardo hangs on upload with RX on
Hello,
I have a Leonardo which will not accept new sketches. There is a sketch loaded that executes when reset is pressed, but when I try to upload a new sketch, the RX lights up continuously and that's it. I get no error messages from the IDE output. Pressing reset will turn off the light but the same thing happens when uploading is attempted.
I know the cable and com port is good because I have another Leonardo that will upload with the same connection. There is nothing attached to pins 0 or 1.
It was working OK until the current sketch was uploaded.
Update: I tried uploading "blink" with the cloud-based IDE and got the following messages:
Upload started
Programming with: Serial
Restarting in bootloader mode
Flashing with command:C:/Users/dpreliasco/.arduino-create/arduino/avrdude/6.3.0-arduino17/bin/avrdude.exe -CC:/Users/dpreliasco/.arduino-create/arduino/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM9 -b57600 -D -Uflash:w:C:/Users/DPRELI~1/AppData/Local/Temp/arduino-create-agent005069387/Blink.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:/Users/dpreliasco/.arduino-create/arduino/avrdude/6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM9
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Update update: I finally was able to unbrick it after many tries at pressing the reset button just before uploading. I guess getting the timing right is a matter of luck.
