Leonardo native USB Midi?
Hi to all. Does Leonardo has native USB Midi (like Teensy for example), I am looking for solution to switch to Arduino board? Thanks.
Yes. See e.g. Control Surface: MIDI over USB.
It does have some limitations compared to a Teensy. For example, the MIDIUSB library doesn't have a buffering timeout, so you have to flush the buffer manually, and it only supports a single virtual cable, whereas on Teensy, you can select up to 16 cables.
Overall, the Teensy boards are much more powerful and have way more memory than the Leonardo, but for e.g. a simple MIDI controller, it should work fine.
