Leonardo not detected by PC, but Uno is
Hi all,
I'm new on the forum, but not on the arduino familly.
I received 2 Leonardo for a simulator project, the problem is not one of them is detected by my computer.
Nothing under : PORT
Nothind under : Other devices
Not magical connection sound from microsoft.
(Yes I read a lot of forum before to post)
I tried the two board with 3 different Micro usb cables on 3 differents computers but nothing works...
Nevertheless my 2 UNOs boards are detected correctly without any problems...
I mean maybe it s the USB cable but i Tried 3 differents, on every ports on 3 different computers...
Is it possible that the firmare is not flashed on the board ?
Any idea if possible to do so and how ?
Best regards,
ArduinoIDE 1.8.12
When using the cables between a cell-phone and a computer, is the cell-phine recognised by the computer? If not, it's a charge-only cable.
If you bought an original Arduino, chances are very slim that the boot-loader is not burned. If you bought a clone, there is a chance.
You can find instructions about burning boot loaders on the web. You can use one of your Unos as programmer; there is a sketch for it in the examples (ArduinoISP).
Tested about 12 cables micro sub and I finally found one !
Why micro usb are not doing the same function and it s not precised on ?
Grrrrrrrrrrrrrrrrrrrr Thank you man
Some cables are just charging cables and the data lines are not connected , these won’t work !
