Hi Guys,
I'm getting the weirdest error. I'm pretty handy with arduino, but this is the simplest of problems and I can't seem to solve it.
Basically, my Arduino Leonardo doesn't send over serial, neither does it respond to serial input.
This is my simple sketch:
while (!Serial); // this is needed for leonardo
Serial.println("start testing");
Serial.println("still testing");
I can upload the sketch fine, so the serial port (COM15 in this case) works. When I send data to the Leonardo using the Serial Monitor, the RX light blinks. But the Serial connection is never established, because I can't get the arduino to respond to the data, and also the TX light never flashes. I've tried this piece of code in the loop() function:
if (Serial.available() > 0)
char x = Serial.read();
if (x = 'a')
digitalWrite(13,HIGH);
digitalWrite(13,LOW);
But it doesn't work.
I've also used a Serial monitor that I made in Visual Studio (C#) where I get the same problem, so know for sure it's not the arduino 1.05 software.
Has anyone had the same problem? Any help would be appreciated!
