Leonardo Not Showing As Controller
I am trying to make a button box controller for PC gaming. I have installed these two libraries, the sketch uploads with no errors, and the board works fine:
#include <Keypad.h>
#include <Joystick.h>
I can’t figure out the code needed to get it to work as a controller.
#include <Bounce2.h>
#include <Keypad.h>
const int     BUTTON_COUNT = 4;
const int16_t DEBOUNCE_DELAY = 50;
const uint8_t buttonPins[BUTTON_COUNT] = {2, 4, 6, 8};
const uint8_t ledPins[BUTTON_COUNT] = {3, 5, 7, 9};
Bounce buttons[BUTTON_COUNT];
uint8_t ledStates[BUTTON_COUNT];
    for (int i = 0; i < BUTTON_COUNT; i++) {
        buttons[i].attach(buttonPins[i], INPUT);
        buttons[i].interval(DEBOUNCE_DELAY);
        pinMode(ledPins[i], OUTPUT);
        ledStates[i] = LOW;
        digitalWrite(ledPins[i], ledStates[i]);
    // Update the debouncers.
        buttons[i].update();
    // When the first button is pressed:
    if (buttons[0].rose()) {
        // Light up the first LED.
        digitalWrite(ledPins[0], HIGH);
        // and turn off all the others.
        for (int i = 1; i < BUTTON_COUNT; i++) {
            ledStates[i] = LOW;
    // When the first button is released:
    if (buttons[0].fell()) {
        // turn off the first LED.
        digitalWrite(ledPins[0], LOW);
    // When any other button is pressed:
    for (int i = 1; i < BUTTON_COUNT; i++) if (buttons[i].rose()) {
        // Toggle its state.
        ledStates[i] = !ledStates[i];
(deleted)
I am trying to make my PC recognise my Leo as a controller. I have managed to make it appear in controllers now, but it still doesn't register button presses.
I added this code:
Joystick_ Joystick;
Keyboard.begin();
     Joystick.begin();
spycatcher2k:
Please describe the issue a bit better!
(deleted)
I am trying, but it's a whole new language. I tried adding the following code.
    int currentButtonState = !digitalRead(index + pinToButtonMap);
    if (currentButtonState != lastButtonState[index])
      Joystick.setButton(index, currentButtonState);
      lastButtonState[index] = currentButtonState;
spycatcher2k:
I don't see where in your code you press the buttons. Perhaps you need to read, and understand the examples supplied with the library. :slight_smile:
When you modify code, please post the complete new code.
It’s not quite clear to me what you want to achieve; I’m not a gamer :wink:
If you want to use the Leonardo as a joystick, you do not need Keypad.h and Joystick.h; those are for keypads and to connect a joystick to an Arduino respectively. You need Keyboard.h and Mouse.h (to send keystrokes and control the cursor / click); see Mouse and Keyboard libraries for available methods. There are three examples in the IDE as well how to use it.
If this is a new language to you, start simple; see below
3a)
Send a text to e.g. notepad
#include <Keyboard.h>
  Keyboard.begin();
  pinMode(A0, INPUT_PULLUP);
  if (digitalRead(A0) == LOW)
    Keyboard.print("Hello World");
    Keyboard.write(KEY_RETURN);
3b)
Move the mouse
#include <Mouse.h>
  Mouse.begin();
    Mouse.move(10, 10, 0);
Note:
Make sure you have a means to stop sending keystrokes / keypresses to the PC or you will have difficulty uploading code. The above achieves that by waiting for the pin A0 to go low; you can use any button.
Thanks for the tips, I'll give it a go.
sterretje:
1)
It's not quite clear to me what you want to achieve; I'm not a gamer :wink:
Note:
