Hey all,
I'm trying to program an attiny84 with my Arduino Leonardo as the ISP.
I loaded the ArduinoISP sketch onto my Leonardo, and the connected my attiny84 to the leonardo with a 6-pin ISP patch cable, as so:
The green LED shows power from the +5V line, and the blue led is attached to pin 2 of the attiny84 (pin 0 in Wiring according to http://bit.ly/14a176S) so I can tell if the code is working.
When I try to upload this through the ISP, I get the error:
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny84
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
which is no good
After some googling, it seems like there was a problem with the Leonardo as an ISP because of the reset pin (http://bit.ly/1zsAthB). So I followed the instructable and rewired to get the above picture (with reset going from pin 10 instead of the ISP header).
Still no dice, though
I'm trying to doing this on Mac OSX, and have had some trouble with using avrdude (as documented in another thread). Does anyone have suggestions for what may be wrong here?
I can upload normal programs to the Leonardo just fine.
thanks!
