EDIT:
My Arduino Leonardo bord works fine on my friends os x but when i try to upload a program from my computer with the latest ubuntu and arduino IDE it starts the upload, tx and rx blinks a few time but before the IDE finishes the board stops blinking and the program i had on since before (from the mac) starts again and a few seconds later the arduino IDE says "Done uploading" without any errors. Its like the board resets itself before the upload finishes...
i started arduino IDE with sudo command now the problems beneath is happening again also sometimes the IDE crashes after the uploading finishes (and works)
When i try to upload to my leornado i get one of the 3 errors in the bottom of this post but after maybe 2-3 tries (it differs) its says uploading done but my program is not running if i upload again however it will run. if i upload a third time then i start getting the errors again. Also sometimes the port used for usb changes from ttyACM0 to ttyACM1 (ACM 0 dissapears and ACM 1 appears in the toolbar) and after a few more uploads to ACM2,ACM3 etc.
Im running a fresh install of the latest ubuntu.
Works good to upload from a mac but not from my computor running ubuntu
avrdude: butterfly_recv(): programmer is not responding
Device code: 0x3f
avrdude: error: programmer did not respond to command: set addr
EDIT: Got a new error
Found programmer: Id = "13
13
"; type = 1
Software Version = 1.3; Hardware Version =
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
EDIT: And now also this
avrdude: error: programmer did not respond to command: write block
vrdude: verification error, first mismatch at byte 0x1200
0x0c != 0x90
avrdude: verification error; content mismatch
