Leonardo, Ubuntu 12.04, Uploading sketches with avrdude.
Hi guys!
I have problem with uploading sketches to Arduino Leonardo manually (without IDE) on Ubuntu 12.04 64bit. Uploading sketches with IDE works great.
  • I downloaded Makefile from here: ::[ edam ]:: » Arduino Makefile
  • Set proper port: /dev/ttyACM0
  • Set proper board: Leonardo (atmega32u4)
  • Compiled sketch.
  • After uploading I got next error message:
make upload
Uploading to board...
stty -F /dev/ttyACM0 hupcl
/usr/share/arduino/hardware/tools/avrdude -C /usr/share/arduino/hardware/tools/avrdude.conf -DV -p atmega32u4 -P /dev/ttyACM0 -c avr109 -b 57600 -U flash:w:test.hex:i
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
make: *** [upload] Error 1
While uploading process RX LED blinks 2 or 3 times.
What I tried to do?
  • Reseting Arduino with the button
  • Unplugging usb
  • Rebooting
  • Changing -b parameter
Please, note: IDE with the same settings and hardware works like a charm.
Where can be my fault? Thanks!
Wow! It's became clear to me that IDE uses uisp tool to upload sketches.
Maybe someone have an example how to use uisp from command line?
I did it!!!
I have added upload.verbose=true to preferences.txt and checked output :slight_smile:
So, to upload sketch to Arduino Leonardo I need next command:
/usr/share/arduino/hardware/tools/avrdude -C/usr/share/arduino/hardware/tools/avrdude.conf -patmega32u4 -cavr109 -P/dev/ttyACM0 -b57600 -D -Uflash:w:sketch.hex:i
Also I have to press reset button on the board before uploading.
Now I have another question. How to upload sketch without pressing reset button?
Great! It works!!!
I have found great tool - ino.
http://inotool.org/
It can make and upload sketches. Works like a charm!
There is a good tutorial for beginners.
Now I have really cool IDE:
Sublime Text 2 + ST2-Arduino plugin + Ino.
Very-very cool solution which can make, clean, upload sketches from Sublime Text 2 window. Also it has syntax highlighting and autocomplete.
