I’ve read the troubleshooting guide, and searched for similar issues. Nothing quite matches my issue.
I can upload and run sketches, and my Leonardo USB enumerates to a COM port that I can connect to, but I can’t get any serial output from that Leonardo COM port.
- Blink uploads and runs fine.
- (Hardware) Serial1 (pins 0 and 1) works fine to my FTDI cable (shows up as COM4 on my system).
- Leonardo enumerates to COM6 when plugged in or reset.
- The Leonardo has nothing plugged into it except the USB cable and ISP programmer.
- The programmer is genuine Atmel JTAGICE3 and it’s clearly working (Blink uploads and runs).
- I use Atmel Studio 6 for development (clearly working with this board and my other Arduino variants).
- Unplugging the programmer and resetting the Leo doesn’t help.
- Device Manager (Windows 7 64) indicates the Leonardo com port/driver is working fine.
- I got the Leonardo driver from the Arduino 1.0.1 distribution.
- I can see and connect to either of the above listed COM ports in my terminal software (Brays Terminal v1.9b).
- Terminal shows expected output from COM4 (FTDI / Serial1), but nothing when connected to COM6.
- I figured out that the loopback test can’t work on the Leonardo variant, but I don’t see that documented anywhere.
- The Arduino itself is an Olimex Olimexino32u4 (Leonardo clone).
What am I overlooking?
Here’s my test code:
#include <Arduino.h>
int led = 9;
pinMode(led, OUTPUT);
Serial.begin(9600); //speed is apparently irrelevant
Serial1.begin(9600);
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
Serial.println("test"); //doesn't work (Leonardo USB)
Serial1.println("test2"); //works great (pin 0, 1)
