Leonardo's USB CDC serial port
I am learning how to effectively use Leonardo/Micro's USB CDC serial port for stuff. I need some help figuring out how to mimic UNO's restart when serial port opens.
After some experimentation, I realized that opening Leonardo's USB CDC serial port won't reset the processor. OK. I have to find software way to do it.
What I tried was using if(Serial). According to the description, Serial==TRUE when serial port opens:
I tried this with the ASCII table example code:
 //Initialize serial and wait for port to open:
  pinMode(30,OUTPUT);
  digitalWrite(30,LOW);
// first visible ASCIIcharacter '!' is number 33:
int thisByte = 33;
// you can also write ASCII characters in single quotes.
// for example. '!' is the same as 33, so you could also use this:
//int thisByte = '!';
  if (thisByte==33) {
    while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  digitalWrite(30,HIGH);
  // prints title with ending line break
  Serial.println("ASCII Table ~ Character Map");
  // prints value unaltered, i.e. the raw binary version of the
  // byte. The serial monitor interprets all bytes as
  // ASCII, so 33, the first number,  will show up as '!'
  Serial.write(thisByte);
  Serial.print(", dec: ");
  // prints value as string as an ASCII-encoded decimal (base 10).
  // Decimal is the  default format for Serial.print() and Serial.println(),
  // so no modifier is needed:
  Serial.print(thisByte);
  // But you can declare the modifier for decimal if you want to.
  //this also works if you uncomment it:
  // Serial.print(thisByte, DEC);
  Serial.print(", hex: ");
  // prints value as string in hexadecimal (base 16):
  Serial.print(thisByte, HEX);
  Serial.print(", oct: ");
  // prints value as string in octal (base 8);
  Serial.print(thisByte, OCT);
  Serial.print(", bin: ");
  // prints value as string in binary (base 2)
  // also prints ending line break:
  Serial.println(thisByte, BIN);
  // if printed last visible character '~' or 126, stop:
  if(thisByte == 126) {     // you could also use if (thisByte == '~') {
    // This loop loops forever and does nothing
    thisByte=33;
    while (Serial) {
  // go on to the next character
  thisByte++;
My prototype board uses TXLED pin (D30) so don't be alarmed.
I was trying to let Micro wait until Serial disconnects and then wait for it reopen to reprint the ASCII table. Unfortunately this only works once immediately following a sketch upload. The LED on D30 blinks and I get the whole ASCII table. If I subsequently close and reopen the serial port monitor, I get some partial table and the LED is not blinking. I guess it never detects Serial becoming FALSE.
Without modification to the ASCII table code, I get nothing after I open serial monitor a second time.
What did I do wrong?
I think Serial becomes true when windows recognizes the USB serial port, and stays that way till the pc or Leonardo resets.
If you want to know when the serial port is opened by a windows-side app, you'll have. To do something else. (and I don't know exactly what...)
Thanks westfw. I might give up developing with 32U4 altogether. Loading sketches bricked my prototypes numerous times.
You can cause a Leonardo to reset by opening the serial port at 1200 baud and closing it again.
I can't recall where I came across that - but somewhere on the Arduino website I think.
...R
