Let Arduino's talk via I2C (with sensor data)
Hello Arduino Forum I am currently working on a project that deals with fire alarm systems, at the moment I am still testing and wanted to use the I2C technology. But I don't have so much experience with the I2C system, at the moment I have one or more problems but I don't know where they come from so I ask you for help.
So one problem is when I work with the following code I get the data on the master but there the "if" commands are ignored?
This is the master code:
int attentionLed = 2;
#include <Wire.h>
  Wire.begin();        // join i2c bus
  Serial.begin(9600);  // start serial for output
  pinMode(2,OUTPUT);
  Wire.requestFrom(8, 4);    // request 6 bytes from slave device #8
  while (Wire.available()) { // slave may send less than requested
    char c = Wire.read(); // receive a byte as character
 if (c == "8/3 ");{
   Serial.print(c);         // print the character
   digitalWrite(2, HIGH);
 if (c == "no  ");{
   digitalWrite(9, LOW);
And this is the slave:
int test_sensor = 0;
#include <Wire.h>
  Wire.begin(8);                // join i2c bus with address #8
  Wire.onRequest(requestEvent); // register event
  delay(100);
  test_sensor = analogRead(A0);
  Serial.println(test_sensor);
void requestEvent() {
  if (test_sensor > 700) {
  Wire.write("8/3 "); // respond with message of 6 bytes (detector adress)
  // as expected by master
  else if (test_sensor < 700) {
  Wire.write("no  ");
Thanks for helping :slight_smile:
Welcome to the forum
if (c == "8/3 ");
Delete the semicolon
It is the only code conditionally executed if the test returns true
Thanks for your answer but i don't quite understand how you mean this, but my goal is to connect 5 detectors to my master so that when the detector 8/3 triggers, the name (8/3) of the detector is shown on an LCD display. That's why I first want to see how it works if I only have one slave that sends its name to the master when the right condition is met and the master then triggers an LED.
A test done with an if statement returns true or false and the whole point of using it is to execute some code when the if returns true or possibly when it returns false
This code
    if (c == "8/3 ");
says "if c equals the string "8/3 " then execute the next code block. In this case the next code block consists of a semicolon and the code block in the curly brackets will be executed regardless of whether the test returns true or false
Incidentally, because c is declared as a char it can only hold a single character (your comment even says so) so it will never equal "8/3 " anyway
Oh ok I didn't know that thanks but how can I make it work?
First remove the semicolons on the if statements
Then take a look at
Serial input basics - updated
for techniques to read multi character strings. Once you have the string you can compare it with fixed strings in you sketch using functions such as strcmp() and others
Thanks i'll have a look when i have time. if i still have problems i'll get back to you in this post.
Can you tell more about your I2C bus ?
Are there long wires or cables and what about pullup resistors ?
Please use binary data for the I2C bus. We don't use readable ASCII strings for the I2C bus.
Would requesting one byte be enough for your project ? Then you have a number from 0...255.
It is actually a school project to represent a fire alarm system, I only want to have around 5 slaves, which is enough. But I don't really have a plan how to program it (I would like to use the I2C bus because a similar kind of system is used in a real fire alarm system).
There are no long cables, it should just stand on the table at a presentation and do its job.
I am trying to get the slave to send its name as soon as it is triggered and the master then gives the slave name on an LCD display and triggers a buzzer.
