ecco questo è lo scketch:
#include <EmonLib.h>
#include <SPI.h>
#include <Client.h>
#include <Ethernet.h>
#include <Server.h>
EnergyMonitor emon1;
//DETERMINA IL MAC E L’IP DELLA PAGINA WEB
byte mac = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
byte ip = {192, 168, 1, 177};
//PORTA DI COMUNICAZIONE
EthernetServer server(8080);
//SCRIVE IL NUMERO DI PIN CORRISPONDENTE AI LED
int ledPin1 = 9;
int ledPin2 = 8;
//LUNGHEZZA DELLA STRINGA INVIATA
String readString = String(30);
//IMPOSTA ALL’AVVIO I LED SPENTI
boolean LEDON1 = false;
boolean LEDON2 = false;
void setup(){
Ethernet.begin(mac, ip);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
emon1.current(2, 17);
void loop(){
if (client) //SE ESISTE UN CLIENTE
while (client.connected()) // SE IL CLIENTE E’ CONNESSO
if (client.available()) //SE E’ TUTTO OK PER INIZIARE
char c = client.read(); //LEGGI I SINGOLI CARATTERI INVIATI
if (readString.length() < 100)
readString += c; //CONCATENA I CARATTERI
if (c == ‘\n’) //VEDE SE C’E’ IL CARATTERE DI FINE STRINGA, PER INDIVIDUARE CHE E’ FINITA
if(readString.indexOf(“L1=1”) > 0) //IMPOSTA UNA VARIABILE DI TIPO BOLEANA (VERO-FALSO) PER GLI STATI DEL LED
LEDON1 = true;
else if (readString.indexOf(“L2=1”) > 0)
LEDON2 = true;
else if(readString.indexOf(“L1=0”) > 0)
LEDON1 = false;
else if (readString.indexOf(“L2=0”) > 0)
LEDON2 = false;
//CREA LA PAGINA HTML (VERRA’ AGGIORNATA AD OGNI ISTRUZIONE NUOVA)
client.println(“HTTP/1.1 200 OK”);
client.println(“Content-Type: text/html”);
client.println();
client.println("");
//TITOLO LED 1
client.println(“
Led 1
//OPERAZIONI DA FARE QUANDO SI CLICCA PER ATTIVARE LEDON1:
if (LEDON1) {
digitalWrite(ledPin1, HIGH);
client.println("Stato: ON
else {
//OPERAZIONI DA FARE QUANDO SI CLICCA PER SPEGNERE LEDON1:
digitalWrite(ledPin1, LOW );
client.println("Stato: OFF
//CREA I PULSANTI RELATIVI A LED1
client.println(“SPEGNI”);
client.println(“ACCENDI”);
//INSERISCE IL DIVISORE
client.println("
//TTOLO LED2
client.println(“
Led 2
//OPERAZIONI DA FARE QUANDO SI CLICCA PER ATTIVARE LEDON2:
if (LEDON2) {
digitalWrite(ledPin2, HIGH);
client.println(“Stato: ON
do
double Irms = (emon1.calcIrms(1480)-0.052); // Calculate Irms only (1480: no. of samples)
client.print(Irms*230.0); // Apparent power
client.print(” dfafa”);
client.print(Irms); // Irms
}while();
else {
//OPERAZIONI DA FARE QUANDO SI CLICCA PER SPEGNERE LEDON2:
digitalWrite(ledPin2, LOW);
//CREA I PULSANTI RELATIVI A LED2
//CHIUDE I TAG HTML PER LA PAGINA
client.println("");
//SI PREPARA PER UNA NUOVA ISTRUZIONE
readString="";
//TERMINA LE OPERAZIONI CLIENTE
client.stop();
