level controller quadcopter
Hello everyone, how are you? :slight_smile:
I have a school project that consists in a quadcopter that I am building with those small syma 5xc motors. I don't intent for now to make it able to navigate like a drone. I just need it to be able to take off and to level autonomously to a determined height value that I will send remotely.
For this project I am using an arduino nano connected to a WIXEL wireless module, DAC0808, ULN2003A as the motor drives and ultrasonic sensors to measure the height. I am not using ESCs or any other dedicated module or shield.
I want to make every part as simple as possible because I am working alone in this project and I still have to develop the code for a PID control. It is not planned for it to fly outdoors or stand against the wind. I want it to stay fixed in pitch,yaw and roll. Just lift over 20cm from a flat surface will be fine.
My question is about the best and simplest strategy to build this quadcopter leveler given my incomes.
First I thought about ultrasonic sensors fixed near each motor and control them individually in terms of height. But still I would have to fix the yaw movement somehow.
Then I went simpler: Placing only one ultrasonic in the middle and using only one arduino output channel to send a same signal to the 4 motors. Is that possible to lift the quadcopter stably the way I need it?
Thank you very much!
Stop right now! You must determine how much ultrasonic noise the motors and propellers make that will interfere with your ultrasonic sensors.
Paul
This is a very challenging project.
