I'm just got my XBees and had a lot of fun already. But I didn'tlike the feeling of just ignoring the 3v3 logik level and connecting it straight to the Arduino. Out there in the internet exist 1000 ways of levelshifting and I don't know which to use. I have some AMS1117 3v3 voltage regulators lying around. Could that work? I also found some ways just using 2 resistors. What is the disadvantage of these methods? They seem a lot easier than buying level shifting chips.
No they are not stable when used as a rapid voltage switch.
Resistors can be used but this slows down the edges of the signal and that can lead to trouble especially at higher frequencies.
I use open collector buffers like the 74LS07.
Personally, I don't think you will have problems with using voltage dividers to do
level-shifting, as long as the resistors are not too large [eg, under 5K], and
as long as the wires connecting the Arduino and XBee devices are short [eg,
under 6 inches].
BTW, Faludi's "book", as opposed to the info shown on his website, as ALL wrong.
In the book, he has no level-shifting at all, and all the figures show the XBee i/o
pins connected straight to Arduino 5V lines, but at least he mentions the XBee
must be run off 3.3V and not 5V.
Also, at least 1 figure in the book has RX and TX connected backwards.
Direct statement from Digi
"To be clear, the inputs to the XBee module are NOT 5V tolerant and cannot accept a voltage level higher than 3.3v on any pin."
why risk it if you can avoid any problems by adding a few cents worth of resistors and diodes?
perhaps Faludi realizes the need for level shifting hence he wrote the article in his website.
Thanks for your replies. I'm going to use the faludi idea with the two resistors and three diodes.
A general question: How do I choose the correct diode? Or probably I have to say it differently: Can a diode be oversized? Of course I'm not talking about a 10K volt diode in a 3v3 Arduino sketch, but what about 50V 1A in this very application?
1N4148/1N914 small signal diodes should work fine, although one of the comments on
the Faludi site talks about using Schottky. Looking again at the webpage, I would rather
use a simple voltage divider to go from 5V down to 3.3V inputs. Then you don't need the
clamping diode.
2.4K series and 4.7K to gnd. You'll notice that this combination has an effective source-
resistance of 2.4K || 4.7K = just 1.6K, which greatly reduces rise-time problems versus
using 10K in Faludi's clamp ckt.
