Levitating a Magnet using PID
Hi, I’ve been working on a magnetic levitation project. I couldn’t get a hall effect sensor, so I’m using a IR LED and a phototransistor. I came across this tutorial on this site
I have been fiddling around with the Kp,Ki and Kd values but still I cannot get the object to levitate. I’m using a coil scavenged from a 12VDC relay. What happens is when I place the object near the magnet it sorts of stick and vibrate for a bit and fall down. :frowning: Any help greatly appreciated.
Here is the code I’m using:-
// Project 13 - Anti-gravity
// 15 Dangerous Projects for the Evil Genius
#define coilPin 3
#define irPin 4
#define sensorPin 0
int A = 2;
// Adjust B to improve stability
int B =60;
int C =10;
int D = 1000;
int maxPower = 255;
long powerCountThreshold = 300000;
int objectPresent = 0;
int monitoring = false;
  pinMode(coilPin, OUTPUT);
  pinMode(irPin, OUTPUT);
  pinMode(sensorPin, INPUT);
  Serial.println("Ready");
  Serial.println("m - toggle monitoring");
  Serial.println("B - increase B");
  Serial.println("b - decrease B");
  static int count = 0;
  static int oldPosition = 0;
  static int ambient = 0;
  static long powerCount = 0;
  count ++;
  if (count == 1000)
    ambient = readAmbient();
    count = 0;
    objectPresent = (powerCount < powerCountThreshold);
    powerCount = 0;
  int check = analogRead(sensorPin);
  //Serial.println(check);
  int raw = 1024 - analogRead(sensorPin);
  // position from top (0) of sensor region to the bottom (650)
  int position = raw - ambient;
  // positive value means going downwards, negative going upwards
  int velocity = position - oldPosition;
  int power = position/ A + velocity * B + C ;
  powerCount += power;
  oldPosition = position;
//  Serial.print(position);
//  Serial.print(",");
//  Serial.print(power);
//  Serial.println(velocity);
//Serial.println(objectPresent);
  // clip
  if (power > maxPower) power = maxPower;
  if (power < 0) power = 0;
 checkSerial();
  if (monitoring)
    Serial.print(position);  Serial.print(",");
  analogWrite(coilPin, power * objectPresent);
  delayMicroseconds(D);
int readAmbient()   //todo try speding up delay in micros
  digitalWrite(irPin, LOW);
   // allow time for LED and phototransistor to settle
  delayMicroseconds(100);
  int ambient = 1024 - analogRead(sensorPin);
  digitalWrite(irPin, HIGH);
  return ambient;
void checkSerial()
  if (Serial.available())
    char ch = Serial.read();
    if (ch == 'm')
      monitoring = ! monitoring;
    if (ch == 'B')
      B += 5;
      Serial.println(B);
    if (ch == 'b')
      B -= 5;
      Serial.println(B);
Here is the photo of my setup
