<LG3.h> Arduino Library
I am trying to use the <LG3.h> Arduino Library for the L3G4200D gyroscope.
Question (1): does this library return "RAW" values from the gyroscope or "converted" degrees-per-second values?
If this library returns raw values, is the following the correct equation for conversion?
Angular velocity = (Vref / resolution) * raw-value / sensitivity
where sensitivity is degrees/ second/ mV?
Question (2): the L3G4200D is running at +/- 250 degrees/s .
How is the sensitivity value "8.75 mdps/ LSB" derived?
If the resolution is 2^16-1 = 65535, I got
500 / 65535 = 7.6 mdps/ digit.
Thanks.
