Trying to get the LH878 PIR sensor to see movement before attempting to build a motion detector on a WeMos D1 mini.
Pins on LH878 are
D which would connect to vcc
S which would be the output of its amplifier
and G which would be the ground
According to data sheet the sensor has a built in amplifier and it requires a 47K load resistor between S and D . So before attempting any code, I would like to see if I could just connect it up to fire a led so I know it will work. As of now I don't have a viable circuit. Any comments would be greatly appreciated here, thanks.
