LI battery charge level indicator build
I'm trying to build a LCD screen that can accurately display the battery level of a Lithium Ion battery. Keep in mind this is for a elegoo V4 Smart Car battery and I want something compatable for that since charging takes up to 3 hours, and it is for a R3 board. How can I accomplish all of this?
What is your question? See the pinned post re 'How to get the most from this forum'.
Does the Elegoo Smart Car V4 have a BMS for safe charging?
An LCD off-line battery monitor.
https://maker.pro/arduino/projects/battery-level-monitor-using-an-arduino
honestly, I'm not too sure.
I'm curious if I can just have the battery on while charging and hook up something seprate to the board
It is an Arduino with a Motor Shield, some sensors, a motor driver and motors, but no battery charging circuit. Maybe a future version will have that.
Charging while discharging a battery would need a special circuit (for example, inside your laptop computer or inside your smart phone) - to avoid the charger supplying too much power to the circuit. Use an offline battery charger made for your battery.
