The shield only comes suited for the Arduino Uno though. Does anyone have the pin out on this so I can adapt it to work with my Arduino Mini? Has anyone tried this ?
spaceuino:
I knnow the pin layout of the UNO and mini, the problem is the pin layout for the sigfox module, so I know how to connect my mini to the module.
You want to bypass everything on the shield? Good luck :-]
Aren't the connectors labeld on the shield? Then check which pins are connected...
