I have been trying to use a huskylens. But, my file explorer is not showing the library folder, even when I try to look everywhere. I even tried uninstalling and reinstalling. Help please!
Hi, @anishpalwa
Welcome to the forum.
What operating system?
What IDE?
What is "huskeylens"?
Thanks.. Tom..
I am using Windows and the Arduino IDE. HuskyLens is a type of AI camera. Could you help me?
What version?
Where do you save your projects?
Look in that folder.
Tom..
What did you install? How did you install it?
I could not immediately find a HuskyLens library on the DFRobot pages (https://www.dfrobot.com/product-1922.html and Gravity: HUSKYLENS AI Machine Vision Sensor - DFRobot Wiki) hence the questions.
Sorry, let me clarify.
I want to learn how to use the HuskyLens camera, and there is some code on a github page and following this Youtube video: https://www.youtube.com/watch?v=AgU_lKmhBn0
I am not able to find the libraries file where he puts it in, though. I am using the most recent version of the IDE and have looked in the file with my projects, but it is not there.
Thanks if you can help!
I had a quick glance at the video. They seem to have downloaded a file from GitHub - HuskyLens/HUSKYLENSArduino. If you did that, you should have a zip file somewhere on your system called HUSKYLENSArduino-master.zip.
Extract that file somewhere (in a place not related to Arduino). In that extracted file is a directory called HUSKYLENS and a file called HUSKYLENS.zip.
You have two options. Either copy the HUSKYLENS directory to the libraries directory or use the IDE to add the HUSKYLENS.zip file.
I used the latter; use sketch / include libraries / add .zip library, find the HUSKYLENS.zip file and click OK.
The issue is, I can't find either of those files to place it in. When I go to my Documents folder, it only shows the program I am trying to run.
Did you install the Arduino IDE? If not, install it.
Next start the IDE, go to file/preferences and check the sketchbook location.
Navigate to that directory using Windows Explorer (or similar for other operating systems).
There should be a libraries (I think it's with lower case L, I can't check now) directory.
This is the issue-I can't find either of those files.
Hi, @anishpalwa
Click on Files, select Preferences.
You should get the page shown below.
What is written in the "Sketchbook Location" window?
Tom..
I wasn't talking about files in in reply #7 but about directories.
This is what I see. the Arduino IDE is installed. Does this answer your questions?
Hi.
It looks like you haven't installed any libraries so far. To fix this:
- Create a folder and call it
libraries. - (Optional, but recommended) Rename
HUSKYLENSArduino-mastertoHUSKYLENSArduino. - Move
HUSKYLENSArduino-master(orHUSKYLENSArduinoif you've followed step 2) to thelibrariesfolder. - If Arduino IDE's open, close and reopen it.
The issue is, I need it to look like this for it to be functional:
Creating the libraries folder doesn't do that for some reason. Could you help me with this?
HUSKYLENSArduino-master is not a valid library. So moving it is not the correct way to do it.
I've seen the repository by now, so let's do it in a different way:
- Download this file (copied from the repository).
- Go to Arduino IDE.
- Go to
Sketch>Include Library>Add .ZIP Library. - Select the file you've downloaded.
Did you try?
Did you read post #7?
I'll have to apologise; I did not realise that you were now suggesting another file for the download
Yes, it worked! Thank you so much!
